Mine (2016 gen2) has been run with 87. Went 43k miles, broke the piston #1 cylinder. I will get it back Wednesday with a new engine (trashed the cylinder wall in that cylinder). I have a thread currently running on it...
Mine (2016 gen2) has been run with 87. Went 43k miles, broke the piston #1 cylinder. I will get it back Wednesday with a new engine (trashed the cylinder wall in that cylinder). I have a thread currently running on it...I'd like to see a poll of all the broken pistons, what percentage ran 87,89,93etc.
I never run anything but 93.
If it's under warranty and your only car, then leave it alone. Making horsepower isn't the issue, but reliability is. If there's mods available with warranty like exhaust , brakes, lowering springs, spoiler, etc then start there.****, I've only ran 87 octane until about 19,000 miles then I switched over to 93. But I want to do stuff to this car because I'd like to get into cars and well this is how I can but I don't want this car to go to **** on me. Is there anyway lets say a mechanic or dealership can inspect my cylinder walls and piston heads?
Not even remotely, unless you do it wrong.Anytime you increase boost on a turBo car you cut its lifespan in half. My subaru lasted 15,000miles at 18psi on 93oct, my 05 civic lasted 11,000 miles at 6psi.
Name one stock turbo car that will last just as long at high boost. Without fully building the engine of course.Not even remotely, unless you do it wrong.Anytime you increase boost on a turBo car you cut its lifespan in half. My subaru lasted 15,000miles at 18psi on 93oct, my 05 civic lasted 11,000 miles at 6psi.
85k isn't much in terms of mileage. I'll do that in 3 years. My cruze has 20k and I just got it in december.My Cobalt started life as a stock, base Cobalt. 85,000 miles and 9 years later after running 16 psi of boost from the M62 and it is still going strong.
The GM 2.0T can handle some severe abuse without going into the bottom end. 3.8L Turbo V6 in the Buick Grand National...
And when I say "do it wrong", I meant put way too much power on a stock bottom end. Your initial post said nothing of that.
So by chance how did the install go? Did you get the Cruze tune on by dealership? How about pics and/or video?I have the GMPP exhaust already install and thursday january 10 the Intake will be install with the tune i will give an update. I'm not expecting a big gain but more power on the low and mid range rpm ont the power band.
Lmk when u installLike I said... I'll take the plunge for the **** of it. I'll post results whenever I get it and it's installed. Really though, it's a plastic/rubber design so less likely to heatsoak. I'm not here to argue anything , but I will report with whatever facts I come across.
