2017 Cruze TPMS relearn tool
12090 Views 10 Replies 6 Participants Last post by  Blasirl
Hi
I'm looking for a tpms (new sensors) relearn tool. Will the EL-50448 do for a 2017 Cruze LT ?
Thank you
1 - 11 of 11 Posts
I hope so. That's what I bought but haven't moved any wheels around yet.
It's supposed to work with both 315mhz and 433mhz systems.
https://www.aliexpress.com/item/fre...es-Coils-Diagnostic-Tool-car/32712361416.html
Actually mine are a new set of sensors extracted from a another 2017 cruze.
Whoa! Now, that's a reasonable price!
I just used my 50448 (purchased from China) to pair an early 2017 wheel with my late 2016 Cruze. (EPC lists 315mhz sensors and 433mhz sensors for 2016, but only 433mhz for 2017, so I assume they changed to 433 midyear in 2016)
Procedure was easy and quick.
Hold start button until car entered service mode (ignition on, engine off). Scroll DIC to tire pressure, hold down the OK button until the horn beeps, then hit LF/RF/RR/LR tires by the valve stem with the EL-50448.
The 2017 wheel was about 5' away from the car, but it recognized fine just like the 3 that were on the car.
The EL 50448 will work as the relearn frequency is around 100mhz for most of GM's sensors. Mine worked even on my 2005 Suburban sensors along with the '13 Sonic and '17 Cruze wheels.
Thank you all for great feedback.
will go ahead and order a relearn tool and give it a try.
Will keep you posted.
MHz or KHz? I'm pretty sure it's a magnetic signal, not a RF one.
Yes:)
Welcome Aboard!:welcome:
1 - 11 of 11 Posts
