So I own a 2017 second gen Chevy Cruze LT.
This car has 78k on the odometer and I have been having issues with it for about twenty thousand miles so far.
My first issue started around 55k which was a hesitation when hot outside and the car had been heat soaked running on the highway for a while. Once on surface streets after the highway it would stumble on itself on acceleration. I originally chalked this up to the auto start system but noticed it does this even in L6. I then proceeded to believe it was the transmission, so I had it serviced (fluid changed) around 58k. The issue has not gone away since. Further more, after the fluid swap on two lane roads I pass regularly. At random when I go to pass the transmission will attempt to downshift as I go WOT to get around the vehicle in front of me. The transmission will feel as though it is going into a gear it shouldn't be and does not accelerate. The engine RPM's go up but I go nowhere. The shift back down can feel violent if I lift and go back on the throttle right away. It almost feels as though it is spinning up the torque converter rather than the gear it needs to be. No check engine lights which is super frustrating. I plan on lifting the car soon to see if I can see anything. I had the shop who changed the fluid look at the level and they said everything looked fine fluid level wise. This happened right after I got the fluid changed so I assumed it was bad fluid level. Drove all through winter just fine until just a few months ago this issue returned. Any idea or help would be appreciated.
