I had wondered about that, and it's certainly possible. From the TSB, this appears to be something added to the gasoline engines for model years 2018-2019. It would not surprise me if a couple lines of code were added to updated versions for ECUs in 2016-2017 model years and it gets loaded on there if you flash to the latest version.So if I subscribe to GDS and flash my 2016 and 2017, will they start running 5th down the freeway in the winter on humid days?
Though, now I'm second-guessing that. The TSB references only model years 2018-2019, and if GM were to add that code to ECU updates for 2016-2017 model years it would create a nightmare where a tech might be trying to diagnose a problem that the TSB doesn't reference for that model year. GM would have to update the TSB to specify this is added to prior model year vehicles if the ECU is updated to or past a certain version of firmware, and then technicians would have to take the step of checking the ECU firmware to determine if it was added to a prior model year vehicle.So if I subscribe to GDS and flash my 2016 and 2017, will they start running 5th down the freeway in the winter on humid days?
My guess is no. Just like an ECM flash doesn't change your autostop temperatures to 18-19 spec.So if I subscribe to GDS and flash my 2016 and 2017, will they start running 5th down the freeway in the winter on humid days?
This is nothing to do with the temperature of the engine. It's 100% the temperature and humidity of the ambient air.But after and hour of driving it should be hot..
Thanks..anything i can do before spend money and going to the dealer?This is nothing to do with the temperature of the engine. It's 100% the temperature and humidity of the ambient air.
This is normal operation. If it's below 30F my car will shift from 6th to 5th after probably a half hour of 50-60mph driving. And won't shift to 6th again during that trip (I don't exceed 70mph typically) this happens everyday on my commute to work (64miles) no trouble codes, no indicators. As mentioned multiple times, there's a TSB (18NA035) that addresses thisI have a 2019 and notied my fuel MPG dropped a lot.. Then i noticed it is not shifting to 6th. But if i drive 80 mph the 6th gear kicks in.. But below 80 mph it drops to 5th. I have lower rpm above 80 then 65..
And yes its about 20°F here. But after and hour of driving it should be hot..
Also if i manually shift it still does not shift to 6th.. Frustrated now
Yeah, you can stop worrying about 8t LOL.Thanks..anything i can do before spend money and going to the dealer?
Thanks I just read the TSB.. I feel better that its nothing major.. Thanks againThis is normal operation. If it's below 30F my car will shift from 6th to 5th after probably a half hour of 50-60mph driving. And won't shift to 6th again during that trip (I don't exceed 70mph typically) this happens everyday on my commute to work (64miles) no trouble codes, no indicators. As mentioned multiple times, there's a TSB (18NA035) that addresses this
I do not know what sensors exist for the ECU to sense humidity in the ambient air, but certainly there are one or more temperature sensors in different points of the air intake system.But if i drive 80 mph the 6th gear kicks in.. But below 80 mph it drops to 5th. I have lower rpm above 80 then 65..
It's possible the Diesel models use the variable vanes on the turbo to run higher boost levels, keeping the air flowing through the intercooler above freezing. Diesel engines can run higher amounts of air and keep the same amount of fueling because they always run lean. I have no knowledge this is what happens, but it's possible.Guess this is only in the gas models. The 9 spd holds 8 for a bit when very cold, then always goes to 9th and never looks back. Doesn't matter how cold the ambient temperature is.
Very true that is possible. I will have to watch the boost on a cold startup drive.It's possible the Diesel models use the variable vanes on the turbo to run higher boost levels, keeping the air flowing through the intercooler above freezing. Diesel engines can run higher amounts of air and keep the same amount of fueling because they always run lean. I have no knowledge this is what happens, but it's possible.
Not must a cold startup drive. It's a drive at highway speeds through climate that is both below freezing (so maybe high 20s F) AND has high humidity. We get that a lot around here: Foggy winter days.Very true that is possible. I will have to watch the boost on a cold startup drive.
