My girlfriend just bought a demo Cruze from a dealer with 6400km on it. 2 hours into our drive home from the dealership I noticed that the car was revving at about 3200-3300rpm which i thought was high. I was traveling at 120kmph btw, and i figure it should be at roughly 2600-2700rpm. so I slowed down to 110kmph and it was at 3000rpm. All traveling on a flat straight. It is winter here and being in Canada it was cold -3 degrees (27 fahrenheit), so just below freezing. I then put it into L and tried it manually. I dropped it 4 gear (revved high as normal), changed it to 5 gear (switched gears and lowered revs) then tried 6 gear and nothing (no change in rpm's). stayed at 3000rpm.
Brought it the dealership and they agreed after the test drive it didn't switch into 6th gear. After investigated it they said they found a form from GM head office that said some vehicles may experience the transmission not shifting into overdrive range during cold ambient temperatures. The conditions may be caused by the engine control system detecting conditions that indicate the freezing of moisture in the charge air cooler. I said that doesnt make sense after being on the road for 2 hours and everything is warmed up. He said it is the way it is programmed.
My question then if it's programmed that way then why is it only SOME and not most or ALL. My step daughter has the same vehicle in 2018 and it doesnt do it to hers. It sounds like to me an out so they don't have to replace it with a new transmission that is defective.
Has anyone experience the same problem and what has your dealership done about it? Do i have a defective transmission and travelling a high rpm's will it put strain on my transmission.
Thanks
Shayne
