I've yet to figure out why some vehicles grind and others do not. My 2012 never had that issue; just inconsistent shifting with OE fluid. Synchromesh never caused a grind unless I spun the tires in wet pavement and shifted, and that was only twice, at redline, in the 60,000 miles I've had this car. After two changes of 75W-90 GL-4, I'm back to Synchromesh, and still don't have an issue with it. Jblackburn, on the other hand, always had the grinding issue, and Synchromesh made it better but did not eliminate it. He has repeatedly noted, however, that 75W-90 GL-4 completely cured his 1-2 shift grind. He's not a fan of Synchromesh.
GM updated the spec for these transmissions to 2.32 quarts, so filling 2.5 quarts won't be overfilling it by any consequential amount.
Are you coming to Lordstown?
