2016 Chevrolet Cruze Limited LT
I have 135k miles on my 2016 Cruze Limited LT
Replacements done on PCV system recently:
  • I just got a hose replaced that's part of the PCV 2 months ago - it had a huge hole in it
  • I changed the valve cover about 20k miles ago
  • I replaced 2 vapor canister purge valves in the past 30k miles
Liquid Mobile phone Telephony Portable communications device Communication Device
Azure Communication Device Fluid Finger Gesture
Communication Device Gesture Finger Gadget Thumb
Sorry, I do not understand the first bullet point. Also what is the question(s) you have?
The first bullet point was about this hose that got replaced (the photo below) - I don't know the name of it, but it's the big one to the right and on top of the engine in the center, part of the PCV system.
My question is: does anyone know what could be going on with the car based on the codes?
Cannon Thigh Human leg Automotive exhaust Engineering
Also, I'm getting these warnings when I turn on the car:
View attachment 298161 View attachment 298160
The two DIC warnings could be caused by a bad neg battery cable.
Service Bulletin - NHTSA SB-10057574-8899
SB-10089945-2280
A P0106 could be caused by: Bad MAP sensor
Water/dirt intrusion affecting MAP sensor connector
Intermittent open in the reference, ground, or signal wire for the MAP sensor
Intermittent short in the reference, ground, or signal wire for the MAP sensor
Ground problem due to corrosion causing intermittent signal problem
A break in the flexible air intake duct between the MAF and the intake manifold
Bad PCM (do not assume the PCM is bad until you've exhausted all other possibilities)
Read more at: P0106 DTC Code - MAP / Baro Pressure Circuit Range/Performance Problem
A code P0131 may mean that one or more of the following has happened:
Faulty o2 oxygen sensor
Short to voltage on O2 signal circuit
High resistance or open on O2 signal circuit
Read more at: OBD-II Trouble Code: P0131 Oxygen O2 Sensor Low Voltage (Bank1, Sensor1)
P07E8
If You own a Chevrolet, You may notice that a variety of lights occasionally appear on Your dashboard. Most of the time, this is because Your vehicle is due for maintenance service, including filters, fluids, and component checks. However, sometimes the light indicates something is wrong. This applies to trouble code p07e8. Most likely, the check engine light has also appeared. This code indicates that there is a problem with the Volume or Mass air flow sensor. If the engine light is also on, it is due to a misreading of the sensor. If the part is faulty, it will need to be replaced. You can expect to pay between $18 and $34 for a new sensor.
From https://www.vehiclehistory.com/questions/whats-the-p07e8-code-chevy-419536
A related thread:
SB-10089945-2280
P07E8
A related thread:
Thanks, man.
I'm taking it to the dealership tomorrow for a free diagnostic, but thought someone might know what it is from experience because it seems suspicious that every single one of the warnings happened all at once. No progresion - just one day all of this stuff popped up.
