35968 miles and I get a check engine
1679 Views 4 Replies 5 Participants Last post by  Cruzin788
I got the check engine 30 miles from the warranty end and p0171.
By the time I got home I was over 36k but I reset computer after checking and not feeling or seeing anything.
One week later back again then 3 days. I changed air filter tightened all connections and CRC cleaned the MAF
No visual or audible vacuum leaks. 36 thousand miles..Did they GM do this threw the ONSTAR...No seriously
any input greatly appreciated.
Dukey
Probably needs a new valve cover (PCV valve) if it's a 1.4L. Pop off the spark plug cover and listen for hissing @ the round disc on top right.
This is covered under 5/100K powertrain warranty.
Yeah I got a P0171 code at around 39K, most common problem is either a loose oil cap or a dipstick not pushed all the way in. Crankcase has to show around 19"/hg vacuum at idle. My problems was a leaky camshaft cover, was covered under the 5 year warranty. But only around a 40 buck part anyway with a new gasket and all new bolts.
Dukey
Welcome to the forum, Dukey!
We can certainly understand your disappointment, and apologize for any inconveniences caused to you by this concern. Although, we cannot provide any technical insight, our team would be more than happy to look further into this on your behalf. Please send us a private message with your VIN, current mileage, full contact information and dealership at your earliest convenience.
Helen
Chevrolet Customer Care
Welcome and hope you get your problem fixed. I'm sure it's something simple.
