The 50# fuel injectors from Overkill Motorsport are ready to sale.
Link: :: Overkill Motorsports :: www . cruzetune . com
Pricing: $199
One of the first things I wanted to do for the 1.4 Turbo community was find a better fuel injector option. I'm convinced these are the best fuel injector option on the market for the 1.4 Turbo.
These are 50# injectors, larger than the 42# green injectors, will better support high boost pressures and E85 tuning. Very importantly, they have a projected spray tip, just like the factory injectors; in testing, these injectors idled just like factory, maintained factory fuel economy, you don't even notice they're there. And if they look similar to the factory units, that's because they're made by the same manufacturer, and will be factory reliable. A one piece electrical connector is included with each injector to make them plug and play with the factory wiring harness, and they come with new injector clips.
A minor mod to the fuel rail is required, you need to cut off the locating tab on each injector boss.
And because I'm not the only Cruze tuner in town, I'm providing the appropriate calibration tables for these injectors to provide to your tuner, should you be tuned by someone else but wish to buy these injectors.
Link: http://www.getoverkilled.ca/cruze50injectortables.jpg
Pricing: $199
