Just like the title says
I have 2012 ECO with 160,000 miles. On my way into work today I noticed a faint grinding on deceleration, clutch out, in gear. Everything else seems normal, shifts smooth, (up and down) no noises while driving, quiet under load, etc.
This isn't going to go away and i'm not imagining things, Is anyone else having problems with the manual transmissions?
Have you replaced your clutch yet (normal wear & tear)? If not I wonder if the clutch pad is gone and you're pad plate to friction plate now.
Clutch is original. I have no reason to believe the clutch is causing the issue.
Only happening when the car is pushing on the "Coast" side of the gears
My son's 2012 LS MT did the same thing - only while off the gas. He thought it was a brake pad failure and the brakes were running metal to metal. Turns out his friction pad had worn away and it was clutch pressure plate to pressure plate. Get it in for the clutch.
