hence the term YMMV.
Your driving habits, traffic patterns, elevation, and heat with a/c play into the gas consumption. Try and find the cheapest reputable top tier fuel (you trust) in 91/93 and try 2 tanks before it gets colder out if you wish to see if it works. I tried 89 and went to 93 as 89 would still pull some timing from me in stop and go idle with a/c on. Even in the winter 87 would pull timing hard from my driving. Now tuned for 93 grade, 93 is as low as I go.So you are saying 89 doesn't even make the grade? I found 91 overkill and at 40 cents a gallon extra. 89 is 20 cents extra and works just fine? Perhaps the key is to have a new engine like mine with 3K before the system gets gunked up, like every computer I have owned? I don't trust Shell after what they did to Florida and Canada about 10 years ago. Interesting GM twist too?
Yep. I'll see if 93 runs in the LS better than the 87 she is using but I doubt she is even using top tier. My next tank to NJ I'll try out costco by Golden Gate. That gas isn't sitting long at those prices usually.hence the term YMMV.
Both of ours cars have gotten several of their worst MPG tanks on Costco gas. The Cruze hates even their 93.Yep. I'll see if 93 runs in the LS better than the 87 she is using but I doubt she is even using top tier. My next tank to NJ I'll try out costco by Golden Gate. That gas isn't sitting long at those prices usually.
I may wait till I get back in town then. I wasn't tunes and had stock gaps when I tried it last summer. The BP I have in now is still going strong. Speaking if gaps, I need to regap again.Both of ours cars have gotten several of their worst MPG tanks on Costco gas. The Cruze hates even their 93.
I agree completely. There are no hills around me. I drive about 1/2 around a smallish (30000 person) town and 1/2 out in the country on 55mph roads on my way to/from work. For me, it makes little sense to spend the extra $$ on premium, especially when it's become a $0.30 per gallon for premium in some cases (like the last fillup).pL2014's driving environment has predominately low engine loads so the higher octane, while improving the car's performance, doesn't appear to improve it sufficiently to justify the extra pump cost. A high load environment (the graph above is an extremely high load) can easily justify the higher pump cost in terms of drivability and fuel economy. Thus my recommendation on how to determine the price/performance sweet spot for each driver.
I live in such a hilly area every single time I try to run less than premium it's very apparent the car has less power and is working much harder to get up some of these steep grades. In my area its consistently 40-60 cents a gallon more for premium, its rare to find a 30 cent difference.For me, it makes little sense to spend the extra $$ on premium, especially when it's become a $0.30 per gallon for premium in some cases (like the last fillup).
