A/C clutch sometimes won't engage
381 Views 1 Reply 2 Participants Last post by  Atlantis Blue RS
2014 Cruze LS 1.8L with 182k miles
This is my first A/C problem. It blows cold until I restart the car during daytime temps, then the compressor won't engage. Freon pressure is in range w/ compressor running, but is well within the red (high) if not running.
Any ideas as to the cause?
1 - 2 of 2 Posts
2013 Chevy Cruze LT RS - Atlantis Blue Metallic. This color is growing on me, miss my black LTZ-RS
Check fuse 62 in the under hood fuse box. My '13 with 1.4 was doing this and I noticed I had a blown fuse. I kept an eye on it and noticed I was only getting an intermittent power connection to fuse. I pulled fuse box and had a bad wire under fuse box. You also may have a bad wire on one of your clutch wires or hopefully just need a blast of Freon.
1 - 2 of 2 Posts
