1 - 4 of 4 Posts
I have a 2013 Cruze literally I was coming out of work and on my screen it popped up “a/c off due to high engine temperature” it has coolant. I noticed the fan is making a loud noise. Someone help!!!
Probably the two coolant sensors.
Watch your coolant temp using the car info on the turn signal stalk. It tells tire air pressure, battery voltage and coolant temp. If coolant is not rising properly (over 200 degrees) when car is warmed up, replace your thermostat.
1 - 4 of 4 Posts
