Anybody have an A-pillar gauge pod mounted in their Gen 2 cruze? If so, where did you get it? I would also like to see pics if you have them
I am currently looking for this as well, did you ever find one that fits?
I assume the Gen II has one as the Gen I certainly does.Doesn't the US model have airbags in the A-pillar? Chinese one does...
Gen II does indeed. The frontmost screw holding the airbag to the body is very far forward, up by the dash speaker grille.I assume the Gen II has one as the Gen I certainly does.
That retainer is called a tether.This one is deployed.Gen II does indeed. The frontmost screw holding the airbag to the body is very far forward, up by the dash speaker grille.
The pillar cover dangles from a retainer that keeps it from flying into the occupant's face.
Not sure how a couple of 2 1/6" gauges and associated wiring would complicate deployment.
I'm guessing it wouldn't be a big deal, but I'm also guessing that no accessory manufacturer would bet their financial future on never getting sued for an untested modification to an airbag cover.
Hey wrex, do you have any pics from this install? I recently did a job on my car and couldnt find this "clutch plate" I saw mentioned a couple times online. Figured it was a gen1 thing since that's really the only thing I could find any info for. I went through the shifter cable boot under the center console area.I don't expect it to have a huge impact with the heating and cooling. Vacuum hose went through the plate for the clutch cable. I used a file and trimmed enough to get the hose through with a round file. (Vehicle is an auto).
This is the one in a Gen I:Hey wrex, do you have any pics from this install? I recently did a job on my car and couldnt find this "clutch plate" I saw mentioned a couple times online. Figured it was a gen1 thing since that's really the only thing I could find any info for. I went through the shifter cable boot under the center console area.
