1 - 3 of 3 Posts
I tried to post in the forum that covered this but is it is closed. It said there is a service bulletin on this but when. I went to the dealer I purchased this car from New they said it didn't effect my 2011 chevy cruze. Wha
t's the deal. Others have said there 2011 where covered?
scan it for codes, its likely an abs sensor worn out, code will tell you which one
the traction control wont work if there is an abs fault, so thats why tc light is on
if it’s not the abs sensor try replacing the neg batt. cable, from what i’ve on this site (i’m having intermediate tc issues myself) certain years/models have bad neg batt cables from the factory. also your plugs and coil might be an issue from what i’ve gathered again from this site. sadly this car is a pc driven car so if something electronically is off it fubars the whole system, because the tc system takes inputs from the drivetrain, steering, brakes, and one other system i can’t think of atm, but white my experience with electronics if one part is off the whole system is off.
1 - 3 of 3 Posts
