I have a 2013 Chevrolet Cruze and this morning my temperature gauge stopped working and the message"AC off due to high engine temp" came on. I woke up and started the vehicle after sitting for 7 hours, it was the same. Obviously it's not hot, help?
Get your thermostat checked. I suspect it's going bad and/or leaking internally.Weird man, mine happened this past tuesday. All of a sudden on the highway the temp gauge rose, the car said car overheating idle car. I put it in neutral and turned on my hazards, within 30 seconds the gauge went back to normal and everything was fine so it seems we are having the same issue. Mine is a 2013 Cruze LS.
That was another idea I had, but I am not sure how I would check that if it would be completely random considering it has only happened once so far and no other issues driving since then. If it's leaking then that wouldn't cause this would it? Coolant would just be going through earlier than expected and would not cause overheating.Get your thermostat checked. I suspect it's going bad and/or leaking internally.
The coolant does seep on this engine. If it's seeping from the thermostat it's covered under the Power Train warranty. You may have to argue with the dealership because a lot of them seem to think the thermostat isn't covered. If it's the water pump it's covered for 10 years /150,000 miles. If, and this is more likely it's seeping out the o-rings from the surge tank cap you'll need to replace that o-ring. The best way to determine this is to dump a bottle of coolant dye into the system. These bottles run about $10 and I keep my coolant filled with it. When the dye comes out with coolant it leaves rather visible fluorescent flakes around the seep point.
In that plastic tank there was none. This is my first experience with a sealed coolant system and so I assumed it was just the overflow tank, before I realized they don't have one. So the coolant level was pretty low though, however it is strange I think it only just happened for the first time with 65k+/- some miles on it. Only happened once until I actually checked it out a week and a half later, was still driven daily.The coolant does seep on this engine. If it's seeping from the thermostat it's covered under the Power Train warranty. You may have to argue with the dealership because a lot of them seem to think the thermostat isn't covered. If it's the water pump it's covered for 10 years /150,000 miles. If, and this is more likely it's seeping out the o-rings from the surge tank cap you'll need to replace that o-ring. The best way to determine this is to dump a bottle of coolant dye into the system. These bottles run about $10 and I keep my coolant filled with it. When the dye comes out with coolant it leaves rather visible fluorescent flakes around the seep point.
What was your coolant level?
The OP, in the first post, indicated the temp gauge stopped working (reading) while driving and the message came on.Please correct me if I'm wrong but I understood that the overheating warning came on almost immediately after starting the engine. In this case... I don't have the full schematic and circuit description for this vehicle but Id guess you have a bad temp sensor or shorted the two wires in it. Try unplugging it and turn the switch on. Temp gauge should read 0. Same if reading the Ecm. The thermal switch will have less resistance as the engine heats up allowing more current flow back to the ecm. Also if the engine is cold and reads hot with the switch on you have an electrical issue. Did it boil over? What was the level in the tank?
how did you fix the issue? mine is doing the same exact thing.I have a 2013 Chevrolet Cruze and this morning my temperature gauge stopped working and the message"AC off due to high engine temp" came on. I woke up and started the vehicle after sitting for 7 hours, it was the same. Obviously it's not hot, help?
