1 - 13 of 13 Posts
So switching from blowing at dash vents to vent and foot all is well. Well today I wanted only feet and for whatever reason the defrost windshield vents would also open. Is this normal??
2013 Cruze LT
You wanted just A/C on your feet???
I had fish and meat in the passenger footwell, trunk was basically full and I wanted to make sure meat didn鈥檛 spill
2013 Cruze LT
Got ya. I just went out and tested and mine does it too. I assume it's too much airflow for just feet.
Any idea folks?
Just a WAG, but I know the AC is also your dehumidifier, might have something to do with that, but probably not:
No air from vents!
Wont kick into Defrost
I don鈥檛 have another Cruze with non auto climate control to reference so not sure. If another Cruze when on feet mode blows through the window defrost I鈥檓 good. I think it鈥檚 a actuator bad since there is a defrost and feet mode combo and it seems it鈥檚 not closing defrost when going to feet only. Fortunately feet and dash vent and dash vent only modes work which I use 98% of the time.
2013 Cruze LT
I literally said mine does it too... does anyone read my posts???
Oops, if it where a snake it would have bit me. Well odd that there is a feet and defrost setting and a feet setting by that also is feet/defrost with a different picture lol.
It sounds like it's either the control head needs a reset, or the gears on the mode actuator behind the speedo broke. I'm betting it's the gears. There's a good diy thread on here for it.
Sent from my SM-G986U using Tapatalk
If the gear mode actuator broke then the mode wouldn鈥檛 change at all. I believe the OP can still select the full range but maybe just leaking some air down to the feet area.
1 - 13 of 13 Posts
