1 - 3 of 3 Posts
So I started to notice when I accelerate between 20-40 mph there’s a rattling sound that at first I thought was the speaker. After I muted the radio I figured out it sounds like it’s right by the driver side tire. Anyone else have this problem. My oil change is coming up but I just want to have a better idea before I go.
I had a rattle at idle and in gear from the drivers footwell area. Turned out to be heater core lines - they added some foam around where they enter the firewall, and it shut them up.
If you hear a metallic rattle with your window down and acceleration, the turbo wastegate arm rattles a bit under moderate load. There is no fix for that one.
1 - 3 of 3 Posts
