Does the 2018 Manual call for UPF64R or PF64?Taking a look at the 2018 Cruze owner's manual it calls for the PF64
The owners manual calls for a PF64, but as that parts bulletin pointed out it has been superceded to the UPF64R on the small gas engine SGE family. The parts catalog should reflect this, and all dealer are supposed to be installing the UPF64R at this point.Does the 2018 Manual call for UPF64R or PF64?Taking a look at the 2018 Cruze owner's manual it calls for the PF64
I just pulled the filter off my 2016, and it's a PF64.
It was installed by my local Chevy dealer in November 2017.
That's 21 months after this bulletin came out:
DATE 02/25/2016
SUBJECT Oil Filter Usage
MODELS 2016 Buick Encore, Chevrolet, Malibu, Cruze, Spark, & Volt Equipped with Engine RPOs LE2, LV7, LFV and L3A
TO All Chevrolet, Buick, & GMC Dealers
ATTN Parts Managers, Service Managers, Service Technicians and Fleet Service and Part Managers
The new small gas engines launched in the 2016 vehicles use oil filter P/N 12667194.
This P/N has been superseded to P/N12670058, then superseded to P/N12674698 (AC Delco UPF64R).
If this part number is unavailable you can use oil filter P/N 12640445 (AC Delco PF64) until stock becomes available for the P/N12667194 - P/N12670058 – P/N12674698 oil filter (AC Delco UPF64R).
Thank you for your cooperation.
END OF MESSAGE
GM CUSTOMER CARE & AFTERSALES
That's what I thought.all dealer are supposed to be installing the UPF64R at this point.
That's most likely it, dealers have massively slim margins for profit on oil changes, so any way to make more they take advantage. They don't get in trouble for installing them, so they keep doing so. There's also the whole some dealers DGAF issue. LOLThat's what I thought.all dealer are supposed to be installing the UPF64R at this point.
So now I wonder if they ran out of the UPF64R, or if my dealer doesn't carry UPF64R because they can get the PF64 cheaper.
I know that Rock Auto wants around $3 for the PF64 and $5 for the UPF64R.
I should have bought a dozen of the bulk pack UPF64RF when Rock Auto had them last year for less than the retail boxed filters. I had no idea Rock was going to quit selling those.
EDIT: RockAuto still has the bulk pack UPF64RF (currently $4.32), they just quit showing them as compatible with a 2017 Cruze. When I check compatibility, it shows no compatible cars.
Same still applies, the PF63 is a longer PF64, and fits just fine. There's not currently a UPF63R or equivalent at this time thoughShows I have a gen 1 I am used to the canister filter and surprised they went back to a spin on filter! When I saw it on rock auto I thought it was a PF47. Now I have 2013 and 2014 I have a case of the canister filters and have to remind myself how to change the oil on wife's Accord with a spin on LOL I remember back in the 80s thinking I could use either a PF51 or PF47 on my 231 Grand Prix. I know the one was for a 229 Chevy V6 and the other for the Buick V6 but they were interchangeable and there was enough room for the larger filter when the PF47 was called for. I had a boss at Nationwise auto parts that informed me of this.
Yeah that's the one I use. Thing is someone brings up something about psi on the drainback and now I'm concerned and might go with the acdelcoMobil 1 M1 113A....
I haven't heard anything positive/negative concerning drainback with the M1 113A filter. If there is a problem, any problem with the M1 113A, I'd like to "see" the test data for confirmation.Yeah that's the one I use. Thing is someone brings up something about psi on the drainback and now I'm concerned and might go with the acdelco
It's not the drain back issue.I haven't heard anything positive/negative concerning drainback with the M1 113A filter. If there is a problem, any problem with the M1 113A, I'd like to "see" the test data for confirmation.Yeah that's the one I use. Thing is someone brings up something about psi on the drainback and now I'm concerned and might go with the acdelco
Ok, that's a different issue. Seems anything at or less than 15 psi is a no go. Did some quick checking on that subject....here's a link:It's not the drain back issue.
M1-113a is a quality filter, made by Champion Labs just like the specified UPF64R. The issue is the bypass pressure spec. While the 113 does(by some accounts) meet the 22psi spec on the PF64, it's believed but not confirmed officially that the UPF64R has a 35psi bypass.
I'll keep using the UPF64R until I get confirmation on the bypass spec. At which point if it is still 22psi I'll switch back to Wix XP like I use on everything else.
