I bought a Cruze that had gone into a ditch and everything was repaired except the Active Grille Shutter (Eco model only)
If you search "Cruz ECO shutter grille explained" it will explain everything about it.
Anyways i got a quote for $525 to replace it. Supposedly this shutter only saves about .5mpg so it doesn't seem worth it but my concern is that the check engine light won't go away even after clearing the codes and I am also concerned that the shutter function might be used for more than just improving mpg such as a cooling function.
Essentially asking if its worth the $525?
