I've wanted to do this! Can you post a how-to? I couldn't find bolts to remove the wheel anywhere and couldn't figure out how to get it off.
There's a YouTube video showing how the airbag comes off, the guy seems frustrated and takes a while and he finally "decides" to just u do one side and kind of push it off the other. This is actually the proper way, he just didn't know it.I've wanted to do this! Can you post a how-to? I couldn't find bolts to remove the wheel anywhere and couldn't figure out how to get it off.
Pictures would be great. Here is a link to the HowTo format: How-To: Write a TutorialI originally searched the forum and google to see if a heated leather steering wheel could be added to my Cruze. I didn't find anyone that has done it. So I bought a used steering wheel and i did it anyways, figuring leather would be nice upgrade alone. Unfortunately the heat didn't work when i first installed it. I eventually figured out the wire harness has wires for it already, but the clock spring did not. I replace the clock spring with PN 84404719 and now the heat works! I have a 2017 Manual LT Hatchback, but this can probably be done on any LT. It's nice upgrade for my winter commute. Hopefully this helps.
