IIRC, the stock 2014 doesn't have DRLs, but uses the low-beam headlights. As such, I can't even guess what may be going wrong. You'd have to know how the added fog lights work.I have a 2014 cruze 2lt and I had my installer put in some LED foglights direct to the daytime running lights, they worked good until 1 night they stayed on ALL NIGHT! I could not get them to turn off and didn't have the space or tools to see what could be causing it. As of now they don't turn on anymore, could it be that it blew a fuse? or what would cause them to stay on all night and then not turn on again?
I've got a 2013 2LT with a 10/2012 production date. I have a spare headlight switch with fogs so I swapped it in. Pressed the fog switch and got no fog indicator light in the dash. I assume then the BCM must be programmed?I do believe I had the switch before I tested it. I went out just now to verify and you do have to have it on via the interior switch first.
I added factory fogs to my car after purchase, and they required a BCM reprogram, if that helps. I just had the dealer do the whole thing. They wanted to charge me for 4 hours. But that included taking the front bumper off. The tech put them on in less than an hour, and didn’t pull the bumper. I requested the price be reduced. After some haggling, if I recall, they changed me $150 for the bcm reprogram and the install. I would figure out the cost with the dealer before you get the work done.I've got a 2013 2LT with a 10/2012 production date. I have a spare headlight switch with fogs so I swapped it in. Pressed the fog switch and got no fog indicator light in the dash. I assume then the BCM must be programmed?
I added the fog lights to my Cruze myself without taking the bumper off. Not that hard. Dealer charged me like $90 to program the BCM, so you got a pretty good deal on yours. :goodjob:I added factory fogs to my car after purchase, and they required a BCM reprogram, if that helps. I just had the dealer do the whole thing. They wanted to charge me for 4 hours. But that included taking the front bumper off. The tech put them on in less than an hour, and didn’t pull the bumper. I requested the price be reduced. After some haggling, if I recall, they changed me $150 for the bcm reprogram and the install. I would figure out the cost with the dealer before you get the work done.
Sent from my iPhone using Tapatalk Pro
I got the kit for Christmas for my 2nd gen. Hopefully I can get it installed this weekend and then make my appointment for the programming. Probably do an oil change and tire rotation at the same time since I'm almost due.I do have the box it came in from Gm,I called and made an appt. Thanks for the reply.
