I wish my turbo setup looked that coolAEM intake installed. Definitely can hear the turbo with this intake kit. The exhaust will stay stock.
LOL! My setup is clean b/c it was just installed.I wish my turbo setup looked that coolmine is all dirty
Simple Green and low water pressure.What's the best way to clean the engine bay without damaging anything?
Just pour and rinse?Simple Green and low water pressure.
Dilute, spray, agitate with a gentile brush, rinse with low water pressure.Just pour and rinse?Simple Green and low water pressure.
While I do miss the WHOOOOSHHHHHHHH under hard acceleration, I do not miss having to turn up the radio every time I was on the expressway to cover the sounds of a central vacuum cleaner being used across the house coming from my glovebox. This 2nd gen, if I want turbo and BOV sounds I just roll down the window. The BOV on the standard is a bit dramatic with the pod filter, and the cabin sound deadening in the hatch is impressive.psssshh^^ I MISS that
It's noisy for sure, g/s are barely higher to the point of not being noticeably different, intake temps are higher when stopped but quickly return to lower when moving, my LTFT are slightly rich but my tune was adjusted and now are bang on.Sounds great and looks great! Noticed any changes? MAF g/s flow increase? Change in intake temps? LTFT changes?
Be sure to spray CRC 656 on the turbo center section to keep it from rusting.Dilute, spray, agitate with a gentile brush, rinse with low water pressure.
I just got done installing mine, super glad the turbo noise doesn't fill the whole cabin while the windows are up like my k&n on the 1st gen.
