Would they not be covered under warranty?I would like something different than stock but yes both sides have worn out and I have had to replace them. Im only at 40k but they both had enough play to wear tires and have a pull.
Reach out to the nice GM customer service folks on this forum. Since you took it in before 36K and had it fully documented, they should be able to help.No not covered. Im in a battle right now with the local dealer over that. The car went in with complaints before 36000 with pulling issues. The tech said there was wear on one side of the car and the other side of the car had a bent rim. But he never looked into why the wear was happening. So at 36500 i did an oil change and other things and found worn bushings. Called at told them and they said its out of warranty no so there is nothing they can do even though it was in for the same complaint before 36000. O well, im ready to move on and upgrade if possible.
