1 - 4 of 4 Posts
Does anyone, or is there any larger injectors? needs injectors anyways, but dont wanna do them and just put stock. Any suggestions or insite?
2011 1.4 Eco 6 Speed
Welcome to the forum and do you plan on tuning the car for larger injectors?
I am running Bosch Green Giants 42 lb, BSH-0-280-155-968-4 from ZZPerformance. 2013 1.4T with ZZP downpipe/mid-pipe
Why? Injector Duty was > 100%
How? I re-tuned it; interpolated the Pressure vs. Flow table for the 42 lbs injectors and then removed 10% from the Injector Offset table, LTFT pretty good across the board I did not adjust any airflows to compensate. I also had to increase Idle speeds because it was too rich and could not lean out the mix at idle.
1 - 4 of 4 Posts
