61 - 80 of 98 Posts
· Contest Manager
Noise problem resolved... don't laugh, it worked!
the noise was from electrical bleed into the PAC, pre RCA
we foil wrapped the PAC to shield the radio waves from it. crazy but it worked.
hmmm got pics lol
or can you explain the whole process?
· Administrator
· Contest Manager
Foil didn't work for me.
Did three layers and no difference.
For me, Since the buzzing sound was only coming from the left tweeter , instead of opening up the whole dash,
First I decided to just wrap the left side crossover.
When I opened up the panel, it hit me when I saw it. The Crossover was sitting right on top of the Power cable that was going to the Amps.
I wrapped it up in a single sheet and then turned on the car.... Buzzing/Hiss completely gone!!! :eusa_clap::eek:ccasion14: :th_coolio: :signs015: :goodjob:
Terry C, Did you try wrapping your crossovers??
Discussion Starter · #69 · (Edited)
Today i took my bass remote and took it out of its case, and relocated it into the center console.
Technology Electronic device
this part was easy... I used double sided weather stripping to secure the board to the outside of the bucket.
Technology Electronic device Electronics Auto part Machine
drilled a hole just big enough for the knob to fit through and rotate properly. Then a smaller hole for the LED
Technology Vehicle door Electronic device
Tested it out of the car...
Vehicle Car Hatchback
The fun part was getting the USB and AUX plugs unplugged! took a bit to figure out how to dismantle the rear console to run the wires under the carpet.
And the final product... I am so happy the knob and the center console are dang near the same color!
I'm stealing this idea is that cool lol love it.
Discussion Starter · #72 ·
Ordered a new center dash lid today. im gonna make a mold and set it up as a cellphone holder and run USB power through it. should be a fun project. I might even put in a solar charger for a spare cellphone battery. waiting on parts ...
Any suggestions on getting the USB and 3.5mm cables disconected, I too am stealing this great Idea but had troubles getting the cables to come apart. any help would be greatly appreciated...
Discussion Starter · #75 · (Edited)
Going to be taking out my mono block amp. it works perfectly, but ill be changing to 2 epic 8's in a few months so i needed a 1000w @ 2 ohm stable amp.
i found a purdy amp to swap out. it will push my L7 to its full potential with 1500w @ 1 Ohm! AND still pound the two Epics when i switch without ever getting warm!
Electronics Audio equipment Technology Electronic device Electronic instrument
Electronics Circuit component Technology Electronic component Electronic device
*FEATURES*
US AMPS MERLIN2 CLASS D MD-2D
RMS 550W x 1 @ 4ohms
RMS 1000W x 1 @ 2ohms
RMS 1500W x 1 @ 1ohm
Low-Pass High-Pass : 40HZ-250HZ -24db/Oct
Frequency Response: 20Hz to 20KHz +/- 1.0 dB
Butterworth crossovers!
platinum terminals
Discussion Starter · #76 ·
My new amp is a power *****, I am looking to get a 2nd battery and upgrade the big 3 right quick. I figure I can keep the 4awg I have running to the battery now, add in a 2 deep cycle, probably a stinger red or yellow top, then have the 1/0 awg come off the 2nd battery to the amps. Any thoughts or suggestions out there? Not sure how many even look at my post.
I read lol I would definitely upgrade yout big three I did lol I also ran 1/0 gauge wire from my battery to my amp and 1/0 gaughe ground wire I would definitely think about that over your 4 gauge.
Sent from my Droid
Discussion Starter · #78 ·
The 4awg between batteries should be more than enough. I might upgrade it later, copper is expensive, so I may wait on that upgrade. Battery will run me about $200, wires, new blocks, fuses. Oh and someone that knows how to wire it. I'm not gonna solo this part. I want it done right the 1st time! I was shocked to find 12awg as my cars ground wire. Really GM, 12AWG?
I'm hitting pretty hard you should check my video out in my build thread lol I ran all my wires under my carpet all the way I am going to be replacing my front bettery real soon then adding a battery in the trunk I almost die driving down the road.
Sent from my Droid
Discussion Starter · #80 ·
going to be installing my 2nd battery this weekend. that battery changes how things are wired, need more fuses, and can use 1/0 awg and the nice thing is the battery becomes its own distribution block. I liked my MB Quart amp, but this US AMP is a HEAVY MONSTER! oh and the amps feet are not plastic, lol they are metal! I was so worried the mb quart amp was gonna melt off the screws holding it down! hehe!
61 - 80 of 98 Posts
