1 - 16 of 16 Posts
I was driving today when my car all the sudden started shaking and had a huge reduce of power... it said “service traction control” and “Service Stabili track” then the check engine light popped up and the codes are “P0261” “P0264” “P0267” “P0270” and “P0302”... the engine slowly started to lose rpm and then died after about 30 seconds idling... I think it’s an electrical issue because why else would all 4 cylinders start misfiring right? Not sure... the car has 65k miles and has never had any problems before... thanks
2013 Cruze LT
Per those codes it looks like it's related to the fuel injectors and their voltages going low. If it's all 4, it could be bad gas or you're low on gas.
it's electrical. check attachments
2013 Cruze LT
I just got gas yesterday.... hmm could it be bad gas?
I mean... it's possible. Check the injectors and the wiring they connect to and around them. It's however very unlikely all would go bad at once unless it's something on up the electrical chain.
looks like a fuse or a short. I'll have to dig deeper as there are test to run to rule out things and I don't have the equipment or the ability to tell the ecm what to do lol
Hmmm thanks for the advice, I’ll check the injectors... most of the codes thrown talk about shorts or open wires, so I’ll definitely check those wires... what exactly am I looking for with the wires? How do I know if they are getting a ground? Sorry for asking so many questions thank you very much for the help :)
Hmm I checked some of the fuses to see if they were broken, but not all of them... I’ll go back and check them all
1 - 16 of 16 Posts
