1 - 1 of 1 Posts
just thinking out loud, but when installing hids for the headlights, im certain that there is no more low watt high beam drl. the bcm still sends out the power for the high beams at low watt which now goes to the relay harness, which without signal from the low beams still wont turn on the hids. but couldn't you take that power the bcm is sending and route it to like the fog lights and use those as drls? you would have to splice that power between the relay harness, to still activate your bi-xenons, and the new drls. the only problem i see is that when you turn on the high beams the fog lights would also come on.
any thoughts, will it work?:confused:
1 - 1 of 1 Posts
