AMSOIL Dominator Coolant Boost
33099 Views 99 Replies 30 Participants Last post by  XtremeRevolution
AMSOIL Dominator Coolant Boost uses surfectants to improve thermal transfer between metal and liquid (coolant) by increasing surface tension.
Specifications
Application: All Cruzes
Quantity Required: 1 fluid ounce per quart of 50/50 antifreeze Or...
1.4L Turbo: 5.8 ounces
1.8L: 6.9 ounces
2.0L Diesel: 9.5 ounces
Each bottle contains 16 ounces
Recommended application: every 30,000 miles
Benefits:
- Reduces warm-up times on 1.4L and 1.8L engines during winter driving conditions, providing heat in the cabin sooner.
- Aids in cooling of the 1.4L turbocharger for improved longevity
- Improves effectiveness of heater core and radiator
- Reduces cylinder head temperatures. This aids in valve cooling and reduces combustion chamber temperatures, which help prevent knock.
AMSOIL Dominator Coolant Boost is similar to Redline's Water Wetter, but tested at ~2x as effective in transferring heat. It is compatible with DEXCOOL coolant/antifreeze and does not affect its rated service interval. This product will benefit anyone who wants to get heat into the cabin faster during the winter, participates in any racing with their 1.4 Turbo Cruze, or simply wants to improve the longevity of their turbo by keeping it running cooler.
Order Information and Pricing:
Warranty Information:
The AMSOIL warranty certificate can be found using the following URL: AMSOIL Warranty
Frequently Asked Questions:
Q: Will my engine warm up faster in the winter?
A: No, the engine itself will actually warm up slower in the winter when the heater is on, because more of the excess heat created by the engine will be dissipated by the heater core to warm up the cabin more quickly. This is a trade-off between fuel economy and comfort until the engine is fully warmed up.
Q: Will this void my warranty?
A: Regardless of what your dealer tells you, the Magnuson-Moss act protects you from having your warranty voided by using a product other than what the dealer recommends. If there is a failure, GM has to prove that the fluid caused the failure. This product is compatible with the DEXCOOL and using it will not void your warranty.
61 - 80 of 100 Posts
Oh, for sure, it'll be fully distributed in probably 5 minutes or so once the system is flowing normally.
When I had the florescent dye put in my cooling system we watched it distribute and in just a few minutes it was coming back through the top return hose.
This product exists for people who don't mind trading a bit of efficiency during cold starts for faster heat in very cold conditions. Based on the threads and complaints that have been cropping up, I'd say there's a large number of people who fall under this category....
I suspect you are 100% correct.
I need to get my buddy's Cruze parked next to mine overnight so I can test them both.
Invite him over, fill him full of beer, point him at the couch. Easy. :)
Yuk yuk yuk.....you'll be in town all week, right?
With interwebz on my phone I'm always in town!
On my way home from work, I set my heater on max and my fan on 2 (out of 4 settings) with recirculate off. I took a video of my temp gauge that was just over 10 minutes long on my phone until it filled up my SD card so I could plot the numbers when I got home. The results are pretty interesting.
I started at 34 degrees F 45 seconds into the video. Ambient temp was 23 degrees, although I'm not sure why there was that discrepancy. The road was 45 mph speed limit in-town driving with stop lights regularly placed. I had to stop at a few.
At 95 degrees, I turned my fan speed up to the 3rd setting. At 6:30, I hit stop and go traffic.
For the next nearly 4 minutes, my car never went past 136 degrees F, although I did start picking up a bit of speed (steady in 2nd gear at 5-8mph, about 1000-1200RPM) at 8:30. My speed never exceeded 140 degrees until several minutes later when the traffic cleared up and I started gaining speed.
What I realized is that this product only helps your car warm up faster if your heater is off or if your engine is inefficient enough to not be affected by the heater core's transfer of heat. During this whole time though, I wasn't cold. In fact, by around 4:00 I started feeling warm air through the vents, and by 5:30 I was getting comfortable and took my leather gloves off. By the end of the recording, my temp gauge needle was right on the first small hash mark past "C", but I wasn't freezing my butt off.
If I had run recirculate mode on like I usually do, I would have been pretty toasty by then, but I wanted to see what would happen under those specific conditions.
So for a french noobie like me. What I need to do to see my car warm faster?
When you start the car, what are you doing? Wich button you press?
This will get you heat into your cabin more quickly in the cold weather. It will warm up the engine more quickly when you're not using the heat, and it will pull more heat from the cylinder head and turbo in the summer (reducing knock under load and heat soak). When I personally start the car, I usually put the vents in recirculate mode and heat on max, fan on 2 or 3. This time, I had recirculate off just so I could see what would happen.
Did some more research on this since it is an area of concern, and I figured out the issue.
AMSOIL recommends tap water or bottled water with this product if run in straight water applications. Why then did these owners have issues?
One ran Aquafina which I have read up on extensively. At first I was looking for corrosive elements like chlorine but found none. Then I realized it is about the most flat and bland tasting water because it has no minerals whatsoever. It is extremely well purified.
Same with distilled water and ionized water. Since those have a polarity that isn't neutral, they will absorb minerals from surrounding metals. This includes aluminum. It will act like a solvent. The use of tap water in fact may be one of the reasons why this product shows so incredibly low corrosion numbers.
50/50 antifreeze is fine with distilled water because it isn't straight water, but that doesn't apply with those cases you mentioned. In those cases, the incorrect type of water was used, which is what caused the corrosion.
Sent from mobile.
Just a thought why some bottled water might be an issue.... I have tested dozens of bottled water for PH level, low and behold those flat tasting waters like auquafina are slightly acidic. Tap water from most citys is sightly alkaline, distilled water is a neutral 7ph. Only bottled water I tested that had a 7ph was ice mountain.
You guys do know that one of the first extremely popular and advertised bottled waters, Evian, is "naive" spelled backwards.
Reactions: 5
Well I have to say this did improve things. I would not turn on the heat till the gauge would get over 1/4 temp so I did not notice the fact that the heat at 1/4 is now noticeably warmer than it used to be. For the money spent on this, I think I would recommend it. I am actually getting noticeable heat at about 1/8 on the gauge now, which has been very helpful getting the windshield cleared. This is not show stopping by any means but again, it is helping and I'm a bit happier now. If you live in the cold and have issues getting the car heated up on shorter/in town trips, this will for certain help out.
Cold weather is coming...
Finally :)
No it isn't, it's getting warmer!!! :)
Shush. Let us enjoy fall before it's gone in 3 weeks.
Cruze taking too long to warm up in the winter?
Cold weather? You mean Cleveland Winter is 16 days away. What was the Amsoil coolant additive to speed the process up again?
Waiting for winter wonderland thread to become active again.
Updated initial post.
Just sent you a PM on usage. Should have searched 1st.
Winter is among us here in CT...waking up to ~20*F already, yay! I put half a bottle of dominator last winter, havn't lost any measurable amount of coolant (knock on wood). Would it be necessary or beneficial at all to put in the other half this winter? It's just sitting on the shelf currently.
If you are still on the same water pump, I would say no. I'm running it for the 1st time this winter after a water pump replacement.
