AMSOIL Dominator Coolant Boost
33099 Views 99 Replies 30 Participants Last post by  XtremeRevolution
AMSOIL Dominator Coolant Boost uses surfectants to improve thermal transfer between metal and liquid (coolant) by increasing surface tension.
Specifications
Application: All Cruzes
Quantity Required: 1 fluid ounce per quart of 50/50 antifreeze Or...
1.4L Turbo: 5.8 ounces
1.8L: 6.9 ounces
2.0L Diesel: 9.5 ounces
Each bottle contains 16 ounces
Recommended application: every 30,000 miles
Benefits:
- Reduces warm-up times on 1.4L and 1.8L engines during winter driving conditions, providing heat in the cabin sooner.
- Aids in cooling of the 1.4L turbocharger for improved longevity
- Improves effectiveness of heater core and radiator
- Reduces cylinder head temperatures. This aids in valve cooling and reduces combustion chamber temperatures, which help prevent knock.
AMSOIL Dominator Coolant Boost is similar to Redline's Water Wetter, but tested at ~2x as effective in transferring heat. It is compatible with DEXCOOL coolant/antifreeze and does not affect its rated service interval. This product will benefit anyone who wants to get heat into the cabin faster during the winter, participates in any racing with their 1.4 Turbo Cruze, or simply wants to improve the longevity of their turbo by keeping it running cooler.
Order Information and Pricing:
Warranty Information:
The AMSOIL warranty certificate can be found using the following URL: AMSOIL Warranty
Frequently Asked Questions:
Q: Will my engine warm up faster in the winter?
A: No, the engine itself will actually warm up slower in the winter when the heater is on, because more of the excess heat created by the engine will be dissipated by the heater core to warm up the cabin more quickly. This is a trade-off between fuel economy and comfort until the engine is fully warmed up.
Q: Will this void my warranty?
A: Regardless of what your dealer tells you, the Magnuson-Moss act protects you from having your warranty voided by using a product other than what the dealer recommends. If there is a failure, GM has to prove that the fluid caused the failure. This product is compatible with the DEXCOOL and using it will not void your warranty.
81 - 100 of 100 Posts
Winter is among us here in CT...waking up to ~20*F already, yay! I put half a bottle of dominator last winter, havn't lost any measurable amount of coolant (knock on wood). Would it be necessary or beneficial at all to put in the other half this winter? It's just sitting on the shelf currently.
No need. The stuff is good for 30k miles. Keep the rest of it for the next time you need it.
I don't know if I posted this before, but I figured I'd share this here so people would get a better understanding of how this product works. One misconception that people have is that your temperature gauge tells you the temperature of your engine. This is not true. The temp gauge simply tells you the temp of your coolant. The oil temp will be different, and the actual cylinder head or engine block temp will be different, with wildly varying temperature ranges depending on what part of the engine you're looking at.
My buddy's car has the ability to scan for both water temp and cylinder head temp. Here's what his scan pulled up, WITH the use of the coolant boost.
As you can see, cylinder head temp is actually 198F while coolant temp was only 165F. This means that there is a gap of 33 degrees between the coolant temp and the actual cylinder head temp, and would have been even higher without the coolant boost. Remember, it is the coolant that dissipates heat into the cabin through the heater core. It is the coolant that cools the turbo. It is the coolant that dissipates heat through the radiator.
What this product does is that it closes that gap. More heat will be pulled from the cylinder head into the coolant, so the coolant will get warm sooner than it normally would. Not only will there be more heat to dissipate into the heater core to warm up the cabin in the winter, but the coolant boost will also allow more heat to be dissipated through the heater core. The end result is that your engine may take longer to warm up, but you will receive heat in the cabin faster.
Of course, this will also keep the engine and turbo running cooler, which reduces knock and improves turbo longevity.
I just wanted to add to this. I purchased a bottle of this and split it between my cruze and my wife's sonic. It made a noticeable difference in the amount of time it took for the heat to get warm in both cars! I was very impressed by this product and would recommend it to anyone.
What's the impact in the summer?
That's actually something that I'm very anxious to test. It will dissipate heat a lot faster through the radiator, but that would not do much but reduce the amount of time the thermostat stays open. However, pulling more heat from the cylinder head and turbo can do a lot for reducing knock.
Sent from mobile.
So how did your car handle the summer heat?
Interesting that the CV has a cylinder head temp sensor in addition to a coolant temp sensor. Never heard of that before...
I ran 89 octane for a while to see what it would be like, and I didn't have any hesitation or throttle lag. Smooth power all the way to redline every time.
Knowing how big of a difference this makes in the winter, I'm just happy knowing my turbo is being cooled better.
My bottle of the coolant boost came in and I added it to my Cruze last night. The engine was still warm from my commute home, so I popped the hood and added it to the coolant reservoir (it did hiss at me lol, but I didn't get burned). I believe that I may have added slightly more than half the bottle, but by no means does it look like I overfilled it. After I added it, I ran the vehicle for a few minutes before shutting it down for the evening.
This morning was cold, windy, snowy and icy. I'm honestly amazed at how noticeable the difference was when using this product. My cabin was quicker to heat up than normal. It wasn't overwhelmingly hot at first, but the fact that it heats up faster on cold starts is worth the price. +1 I highly recommend Dominator coolant boost.
Probably a dumb question but should you suck out an equivalent amount from the coolant tank before adding Dominator? Also, does coolant circulate through this tank when the engine is warmed up and the thermostat is open? If not, how does Dominator get mixed in with the DexCool?
Coolant circulates through the tank, it will mix.
Yes, the coolant level should be corrected for anything added to the system.
Do you think I'm risking anything with an extra 6+ ounces flowing in the system?
How much longer does it take for the engine to reach operating temperature using this product in the winter? These cars take a decent amount of time to reach operating temperature in winter as is without pulling even more heat out.
I haven't really kept track, but the engine gets up to temp within 5-10 minutes of actual driving. Once you hit highway speeds, you're up to temp in no time. It's city traffic that varies. If you're blasting the heat in stop and go traffic on a single digit day, you're not going to be able to get past the 1/4 mark till you get moving.
There's also the benefit of cooling the turbo better in the summer.
I added it to what was already in my tank. Don't think that small amount is going to do any damage.
Check the level. If it's too high, adjust it. It won't do any harm. If anything, running it too low could cause a problem. Running a bit higher won't harm anything.
I tried shooting you a PM with a picture of my coolant tank after my drive home from work, don't know if it went through or not, but I figured it would be helpful to others if I just posted it in this thread. Anyway, here's a picture of my coolant levels on my 2015 Cruze LT after my 18 mile ride home from work. Keep in mind I added the coolant boost a couple of nights ago, and ended up adding a little more than half the bottle. Too much? Looks good? Do I have to remove some? What does everyone think?
Auto part Vehicle Car
That's fine. The full line is for a cold system.
I still have a half bottle of coolant boost. Probably been sitting in the closet for a year and I noticed it has white flakes inside bottle. Does this mean it's no good anymore?
Mind taking a photo of that? I haven't had one sitting around for any length of time so I don't know what it would look like in storage once opened. It could have gone bad. I'm not exactly sure.
Oh, I thought you meant it was sitting at the top. That's most likely some of the top layer of fluid that oxidized and settled at the bottom. I wouldn't be worried about using the rest of it. I'd probably filter it through a paper towel first.
