My only question is were did all the material build up go? Valves? ports? cat? or did it get burned up?
Order Information and Pricing:"Wow! Wish i could have taken before and after pictures. The condition of the sparkplugs was unchanged. The top of the pistons however went from a uniform color of brown to a good chunk of shiny metal getting close to being brand new again. There were still areas with light carbon build up but the cleanliness was about 60% improved. Kudos PI!"
Gets burned up and blown out of the exhaust.My only question is were did all the material build up go? Valves? ports? cat? or did it get burned up?
So don't use this right before you're going in for an emissions test.Gets burned up and blown out of the exhaust.
I was thinking the same thing - my wife's Solara almost never goes more than a mile from engine start to engine stop. Her fuel economy sucks but she can go over a month between fill ups.I should probably try this out on my wife's car. She's always stuck in traffic and I can imagine the carbon build up.
Correct. It will however improve the emissions reading (in applicable states) the following tank.So don't use this right before you're going in for an emissions test.
That will help a bit if it's really bad but it isn't a preventive approach to the problem. The owner who wrote the review I posted owns a 1.4T Sonic, tuned, and drives it hard in the SW region making trips to Vegas in excess of 100F ambient at times. Cruises at 80mph, which it you've seen the area will remember consists of many significant grades for miles at a time.You should take those cars out on the hwy once every couple months and beat it a bit to clean out the carbon.
Sent from the sexy electrician
Or maybe the oil filter. I always run this stuff a couple of times before my oil change which is looking like will 11 - 12 months for me. So that way in case there is any gunk that goes to filter I am getting it out.Gets burned up and blown out of the exhaust.
From the combustion chamber into the oil filter? I don't see any likely way that carbon that is burned out of the engine over the course of 400-500 miles is going to be caught shortly afterward into the oil filter. That would have to seep down past the piston rings (compression and oil seal) and contaminate the oil before finally being pumped through the filter.Or maybe the oil filter. I always run this stuff a couple of times before my oil change which is looking like will 11 - 12 months for me. So that way in case there is any gunk that goes to filter I am getting it out.
