Android Head Units and the Factory Pioneer System
862 Views 9 Replies 4 Participants Last post by  Canadian_Syrup
Hey everyone,
I've been looking into some options regarding replacing the factory MyLink screen with something Android Auto capable and likely will end up with one of the Tesla screens (I don't want a non-functional CD slot just sitting there, or potentially all the center stack buttons not working), but the big thing that seems very hit or miss - and incredibly undocumented in terms of all of these units is whether or not they are plug and play with the factory Pioneer amp/speakers.
I have looked through numerous posts and seen that some are and some aren't. I am interested in the ones that are, specifically as to why. I have a feeling they have a certain pin in the large main connector that goes to the car's harness (that used to plug into the back of the factory radio) that, I assume, gives the amp its turn-on signal.
Just figured I'd see if anyone knows off hand, as I have no interest in cutting up the car's harness.
Thanks!
1 - 10 of 10 Posts
Bummmmp
I've seen that one before, but unfortunately it is not applicable as it does not retain functionality of the control panel there, and the CD slot becomes non-functional as well.
The iDatalink Maestro seems to be more or less similar to what most of the Android units come with, though there is major inconsistency between them. I have to assume the amp turn on lead from the unit could simply be pinned into the harness that connects to the car, but I don't know for sure.
Hey everyone,
Thanks!
I would probably get one of these screens too, but I would like my Pioneer speakers to work. Where do you get one and how much do they cost?
There are like four million different ones - I mean, most of each style is the same, it just depends on some specs, the "brand" name, and how much it costs - though some seem to definitely vary in terms of the wiring to the vehicle side. For instance, most don't seem to work with the Pioneer system (without some kind of wiring changes) - but some do right out of the box.
I'm trying to figure out why. If it's as simple as pinning the remote turn-on lead into the connector in the right spot, then that's a pretty simple solution - but there are two pins that could be that connection...
I'm thinking about getting one just to mess around with it.
If you happen to get one before I do and want to try pinning in the Pioneer system into the main connector...
"Amplifier Control" is Pin 37 while "Entertainment Remote Enable Signal" is Pin 43 (both are also found back at the amplifier)...not sure which one of those wants the amp turn-on wire (and then what does the other one do?)
I'd glady do that for you, but you kinda lost me all the wiring terms. 😀
  • Haha
Just installed one on my 2014 LT with Pioneer sound system. Audio is coming out but extremely distorted once volume is turned up. I'm going to try powering the amp based on this video (2) Tesla Android Radio Chevy Cruze with Pioneer System Install - YouTube and see if that does the trick. Also having issues with no volume from Bluetooth (calls or music) as only the FM radio seems to produce audio.
1 - 10 of 10 Posts
