2012 Cruze LT 1 automatic, This car is something else, since 30,000 miles we have had the Tourqe converter seal replaced, cam seals, oil pan gasket, valve cover with the wonderful Pvc valve, the water pump leaks around the bolts and gasket when it gets real cold outside, and now at 96,000 miles the upper coolant hose sprung a leak right at the water outlet, I replaced hose and still a slight leak but not bad at all. But too the OEM HOSE CLAMP off and put a worm clamp at the radiator inlet because I got tired of trying to get the spring clamp back on. So now I will probably get another gates hose 23800 I believe and replace it with two brand new OEM Clamps if I can figure how to get it on at the radiator inlet. Anybody replace their upper hose could let me know how you got in there without taking something else apart to get that bottom spring clamp on. Ohh and we are out of the great powertrain warranty in September, so guess will be working on this POS of a car every month or whenever something takes a crap on it, which so far makes me want park it in the bad side of town and leave the key in it running maybe I can go get me a toyota then. Sorry just venting, I just love spending my weekend working on this great car.
