Where on the bellhousing was the drip? See my thread below; there is a drip on my transaxle that I am worried is the same thing. Cannot find where it is coming from.
Thanks, that is very helpful. I think mine must be coming from somewhere else as I don't see any near the weep hole (?) that yours seems to be coming out of. Mine is a much smaller amount, just appears as a drip but enough to be collecting in the underbelly liner. Good luck on the rest of your project ... will be interested to hear if your modifications work out, since I think all of us with manuals may end up facing this sooner or later.Here are a couple pics. Right at the bottom.
I'd image pretty high. Near 100% wouldn't surprise me. I'd imaging i'll be doing this again. The good thing is that this car is pretty easy to work on. WAYYYY easier than the civic it replaced. A car that is easy to work on but requires lots of work is only marginally better than one that is awful to work on but seldom requires work...I wonder what percentage of manual transmission Cruze will eventually be affected by the defective slave cylinders. Do you think it will approach 100% of those still on the road?
Yeah, to change a slave cylinder involved dropping the transmission?!that sounds like a lot of work lol
I'd like to know if there is a redesigned part. I've not seen any evidence (such as a part number change) to indicate something was changed.The replacement from GM is a complete redesign (with no grease), so hopefully they addressed the issue.
Don’t know about the slave cylinder number, but the replacement cylinder (GM 55597066 is what I got for my 2017 diesel) is entirely different from what was originally installed. And the old version used a simple o-ring for the line connections; the new had a sort of lip seal that would not fit the original bleeder assembly, even though it has the same bore. So I used the old short line instead of the line sent with slave cylinder (with o-rings). There also is TSB PIP5558C, that describes another failure in the line from the master cylinder to the bleed fitting on the transmission. It has an accumulator in it that generates particles that get stuck in the bleed fitting, and the symptom is clutch pedal dropping to the floor without actuating the clutch. Got one on order, just in case.I'd like to know if there is a redesigned part. I've not seen any evidence (such as a part number change) to indicate something was changed.
I am fully aware of that TSB. The slave cylinder on my car failed TWICE and was replaced TWICE under warranty, and is still warrantied until Feb of 2024 from the second replacement.There also is TSB PIP5558C, that describes another failure in the line from the master cylinder to the bleed fitting on the transmission. It has an accumulator in it that generates particles that get stuck in the bleed fitting
I like my Cruze, but these sort of incidents support the idea that the government should have never bailed GM out.
