Welcome Aboard!Bought a aftermarket touchscreen to put into my 2011 Cruze.
I’ve tried to unclip the connector but can’t remove without breaking. Is it suppose to be removed? Below are two images. The first is the clip I can’t remove. The second is the connector that was sent with aftermarket system. I assume if I removed clip that it would fit?
It has been some time since I had disconnected an antenna at the roof. I did so at a junkyard, but I remember it being fairly easy. So I assume this one is at the radio. Can you take other pictures of it from different angles? It looks like it has a lock on it, but I need a different view to see how it works.
