I started mine today too. I'm about 1.5 hours in. I chose not to remove the air hose from the turbo and instead just pull that back. Some of the connectors and hose clamps were weird and I didn't want to break them, so I just removed the air hose from the MAF and pulled out the box, still plenty of room. For the clip that goes into the top belt cover I just clipped the zip tie and left the fastener in the cover. Easier to just run a new zip tie. I also pulled out the inner fender panel out.
Tomorrow my plan is to get the radiator drained, support the motor, pull the mount and bottom cover, pull the crank pully, lock everything in with my timing kit and take the belt and pump off. Unless I really screw something up the whole process should only be about 4-5 hours.
So far it has been not frusterating at all, which is nice. Brad's and the other guys videos were nice because knowing what to take off before even trying is a lot easier than just starting and constantly being blocked by something as you are trying to figure it out for yourself. That is very frustrating.
