61 - 74 of 74 Posts
Discussion Starter #61
The default tach says 0 rpm. I added a few random gauges and they worked.
It's possible that gauge is using the old ID system. (so its ID would just be 12). The new system just uses a generic random number because 12 doesn't differentiate between ECM and TCM or other sources of Engine Speed. The gauges are suppose to migrate to the new system but maybe it's not working right.
Just hold it and release it in the same spot. Then click remove. Then just add a new "Engine Speed" from the ECM. Then it should have the proper ID.
There is two of those PIDs with the same name. I renamed yours to DPF Soot Accumulation Holden/Korea.
Sorry to be super annoying :(
I can't see that renamed PID. I can see soot accumulation in grams and as a % (which are all red).
Other PIDs work such as engine speed etc.
Thanks.
Discussion Starter #64
Thanks.
Sorry I have a lot of things to keep track of but the DB version with THAT pid is now in the app. Give it a day for Google to process it.
Discussion Starter #67
New update!
Has quite a few more controls across the board. For the diesel Cruze the new stuff (and some old new stuff) is...
  • DEF Heater Controls
  • DEF Injector Controls
  • DEF Pump and Purge solenoid controls
  • Other misc DEF, NOx, DPF, etc resets
  • Power Relay Controls i.e RAP Relay
  • Cooling Fan Controls
In addition...
  • You can now turn the screen when selecting PIDs without it clearing your selections or scroll position. Yes this one made me angry too.
  • Categorical (enumerable) pids are now scheduled slower. This should help keep data traffic to a min.
  • All modules on the network will now show up, including gateways and HMICMs.
Discussion Starter #68
Also due to COVID it may take some time to actually update on your device. Unfortunately there is not much I can do to speed things up.
Discussion Starter #69
Hey guys. Past month has mostly been stability and tiny updates.
  • The UI Lifecycle has been reworked. Before it utilized Android's built in stuff but now it just handles it on its own which is much safer.
  • Some client-server desync issues have been fixed. Again insanely rare anyone ran into these issues as they self fixed themselves but things should just happen quicker now. Sometimes you would see "Channel Closed" on the PID list.
  • Android Q dark mode is now supported. You can enable it by enabling "Battery Saver" or "Dark Mode" or "Night Mode" on your phone. Only the newest Android OS supports this. The changes are minor but its made to match other Dark Mode apps.
  • The stupid bug where the Data View menu crashed when empty has been fixed.
  • ELM327 mode has been stripped down even further to hopefully allow more junk china adapters to work. ELM mode isn't near as good as OBDLINK mode. There will be random issues. The app will always recover but some things like pulling a large list of DTCs may not work correctly. There is no fix for this.
  • A new bluetooth pairing system is ready but unfortunately it is broken internally in like 80% of phones. It's unlikely this will be added until Google fixes it (if they fix it...).
Some future focuses
  • Add ability to reorder dash items.
  • Add ability to modify dash grid size.
  • Fix dash popup menu not showing up correctly when in horizontal.
  • Implement record mode on server for future graphing system.
  • Improve user feedback to issues
  • Make workarounds for Android bluetooth issues :rolleyes: interfering with initial connection to devices.
Discussion Starter #70
Small update:
  • An Android bug causes a crash when the OBD2 service is started. Some changes have been done to minimize this happening but sadly it’s an Android bug not a Gretio bug. I have personally never replicated this bug but as more and more people are using Gretio it’s popping up rarely.
  • The dashboard now saves the ‘Z’ position of your instruments. This means you can now reliably have gauges lying on top of each other.
  • More commercial vehicles should now be auto identified (I.e. chassis cabs).
  • Key fob programming has been added. Programming a new fob can be a little finicky with this method, but deleting previous key fobs is very easy. You can follow the Key Fob Identifier PIDs.
Discussion Starter #71
Latest 'beta' version adds SWCAN abilities for applicable devices. So you can now see things like the radio, DIC, etc... Right now its a little unruly but some upcoming changes will help fix that. Since we need a little more 'context' to help keep track of things the old database will be wiped. Not a big deal just means you have to go through a scan again. At the moment we only have PIDs for the Inflatible Restraint Module, but I'll see if I can get some more in.
Just wanted to say I have been loving this app, in particular how quickly it connects and brings up the gauges, and of course being able to see the DPF and regen it manually is so helpful. Thanks.
Discussion Starter #73
Hey guys. The current beta version will likely remain in Beta for at least another month. You can get the beta versions by just visiting the store pages. Gretio - Google Play
But the latest beta introduces drum roll PROGRAMMING... Okay not tuning. Just programming. All you can do right now is turn on the HVAC Afterblow and do injector IQA programming. There isn't really a whole lot you can program on the scan tool side of things.
And there are realtime graphs now :). They work just like any other instrument and have a good amount of customization.
Discussion Starter #74
Here is the lengthy error log of using a common amazon bluetooth adapter.
Too long don't care? Get the OBDLINK.
Code:
2020-05-30 20:09:32.304 11851-11956/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:38.705 11851-11978/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:44.256 11851-11956/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:46.906 11851-12013/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:47.555 11851-12021/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:48.107 11851-12020/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:48.110 11851-12020/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:09:49.707 11851-12013/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:50.958 11851-12014/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:51.508 11851-12013/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:51.511 11851-12013/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:09:52.298 11851-12014/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:52.956 11851-12021/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:52.959 11851-12021/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:09:54.555 11851-11972/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:56.455 11851-12014/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:58.005 11851-11972/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:58.555 11851-12013/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:09:58.559 11851-12013/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:09:59.756 11851-11972/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:02.505 11851-11956/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:03.055 11851-11972/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:03.058 11851-11978/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:10:03.846 11851-12021/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:04.405 11851-12020/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:04.408 11851-12020/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:10:04.954 11851-12021/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:07.154 11851-12013/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:08.157 11851-11956/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:08.955 11851-12014/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:12.405 11851-11955/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:12.955 11851-12021/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:12.958 11851-12021/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:10:13.604 11851-11978/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:14.159 11851-11978/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:14.162 11851-11978/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:10:16.053 11851-12021/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:17.055 11851-12020/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:17.905 11851-12014/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:18.455 11851-11955/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:18.459 11851-12014/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:10:19.569 11851-12013/com.surrealdev.max E/Elm327Device: UNEXPECTED FEED INTERRUPT! Data Error CAN ERROR. Counts: 1
2020-05-30 20:10:20.005 11851-11956/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:21.053 11851-12020/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:21.604 11851-12013/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:21.606 11851-12013/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:10:22.155 11851-11978/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:25.053 11851-11978/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:26.103 11851-12013/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:26.654 11851-11955/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:26.657 11851-11955/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:10:27.303 11851-12021/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:27.855 11851-11955/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:27.862 11851-11955/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:10:28.404 11851-11978/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:29.495 11851-12020/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:30.054 11851-12021/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:30.055 11851-12021/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:10:31.106 11851-11978/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:32.204 11851-12013/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:32.755 11851-11956/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:32.758 11851-11956/com.surrealdev.max E/GMLAN: GMLAN INIT FAIL message timed out during init?
2020-05-30 20:10:34.203 11851-11955/com.surrealdev.max W/Request: $2C request timed out for msg to 7E2.
2020-05-30 20:10:35.004 11851-12014/com.surrealdev.max W/Request: $2C request timed out for msg to 7E2.
2020-05-30 20:10:36.353 11851-12020/com.surrealdev.max W/Request: $2C request timed out for msg to 7E2.
2020-05-30 20:10:37.159 11851-12014/com.surrealdev.max W/Request: $2C request timed out for msg to 7E0.
2020-05-30 20:10:38.552 11851-12013/com.surrealdev.max W/Request: $2C request timed out for msg to 7E2.
2020-05-30 20:10:41.746 11851-11972/com.surrealdev.max W/Request: $2C request timed out for msg to 7E2.
occasionally it just fails until an internal monitor kills it. This is the most concerning and can only really be explained by some hardware issue or a deep firmware flaw.
2020-05-30 20:16:10.641 11851-11955/com.surrealdev.max E/Elm327Device: UNEXPECTED FEED INTERRUPT! Data Error CAN ERROR. Counts: 1
2020-05-30 20:16:11.733 11851-11955/com.surrealdev.max E/Elm327Device: UNEXPECTED FEED INTERRUPT! Data Error CAN ERROR. Counts: 2
2020-05-30 20:16:12.808 11851-11955/com.surrealdev.max E/Elm327Device: UNEXPECTED FEED INTERRUPT! Data Error CAN ERROR. Counts: 3
2020-05-30 20:16:13.902 11851-11955/com.surrealdev.max E/Elm327Device: UNEXPECTED FEED INTERRUPT! Data Error CAN ERROR. Counts: 4
2020-05-30 20:16:15.008 11851-12014/com.surrealdev.max E/Elm327Device: UNEXPECTED FEED INTERRUPT! Data Error CAN ERROR. Counts: 5
2020-05-30 20:16:16.084 11851-12014/com.surrealdev.max E/Elm327Device: UNEXPECTED FEED INTERRUPT! ERROR LIMIT EXCEEDED Data Error CAN ERROR. Counts: 6
There isn't anything entirely bad about a message timing out. Gretio is made to handle it. On the OBDLINK timeouts do happen, mainly due to Bluetooth being crap. But timing out is rare with the OBDLINK. You may get like 2 timeouts over an entire session.
Even more concerning is sometimes the data is just flat out wrong but this is rare. Around 1 in 100,000 messages. This NEVER happens with the OBDLINK.
Does it work? It depends on your definition of working. Assuming it gets past the initial stage and you keep PIDs to a min, it should be fine. But even getting to that is a challenge.
61 - 74 of 74 Posts
