are you using an iPhone? Because with the iPhone once plug in the USB carplay take over and disconnect from bluetoothYes, I got a call the other day on the MyLink screen. My phone was paired to Bluetooth as well as plugged into the USB.
Yes, iPhone 6. It does not disconnect from Bluetooth when plugged into USB. Audio streaming defaults to USB instead, but phone calls will still go over Bluetooth. Incoming call information shows on the 8" screen and DIC as well.are you using an iPhone? Because with the iPhone once plug in the USB carplay take over and disconnect from bluetooth
You must have the Apple Carplay disable because when carplay is unable it is in control and the Bluetooth get disconnectedYes, iPhone 6. It does not disconnect from Bluetooth when plugged into USB. Audio streaming defaults to USB instead, but phone calls will still go over Bluetooth. Incoming call information shows on the 8" screen and DIC as well.
