1 - 7 of 7 Posts
I just bought a new car in Melbourne, Australia.....a Holden Astra Sedan MY18. It's a rebadged Chevy Cruze built in South Korea. Other then being RH drive almost everything about the car is nearly identical and certainly the closest thing I can reference when working out what I need to do for my upgrade.
I have the 6 speaker setup with no no amp....so dash, front, and rear doors. There are no plans to replace the stock head unit.
I'm more concerned about SQ then SPL
The ideal end point is to end up with is to replace the front doors and dash speakers and set up an active front end as well as add a sub of some variety to round out the system.
I want everything to look stock and will be using the stock speaker locations.
The sub would need to take up the least amount of space possible as we use every bit of that boot(trunk) space and was a big reason for purchasing the car so I would be shot if I filled it with a sub and amps. Easily removable for those times when its needed could help alleviate some of that possibly.
The have a Kicker Hideaway sub that was in my last car that I plan to use under one of the front seats to help give me some decent tunes as the project moves forward but will take it out once a real sub is added to the system.
The tentative plan is:
Stock HU > Audiocontrol LC2I LOC > DSP (MiniDSP or Dayton DSP-408) > Amps (4 & 1 Channel or 5 Channel) > Mids/Tweets & 8" Sub
I don't really plan on using the rear speakers so will disconnect them at some point.
I have some ideas on a good 2-way combo but open to ideas or opinions.....I'm a bang for the buck kind of person.
Mids - Dayton RS180P-4 - 7" 4ohm Paper
Tweeters - SB Acoustics SB29RDNC-C000-4 - 4ohm Neo
Sub - Need some help here...prefer sealed for SQ and space savings...suggestions welcome!
I want to do some sound deadening of the front doors and boot(trunk) area but options are fairly limited here in Australia in that regard so this will be a work in progress and take a decent amount of research most likely. If any aussies can chime in that would be great!
I want to try and keep everything minus the sub in the cabin area (dash, center console, under seats) if possible again to save space in the trunk unless it's possible to mount some things behind the panels but I haven't removed those yet to see how much space is behind there.
Lastly, I live in Melbourne, Australia so I don't have access to as many resources as the US does so exchange rate and shipping for anything overseas can add up fast.
Any comments....suggestions.....and advice welcome! Any aussies with good Astra knowledge also welcome as the resources for that over here is almost non-existent.
I'll attach a few pics of the car which should look very familiar.
Land vehicle Vehicle Car Mid-size car Hatchback
View attachment 270687 Land vehicle Vehicle Car Hatchback Compact car
This thread references a Gen I US built Cruze, but I imagine a lot of it will still be useful:
The SQ Car Audio Thread V2
Thanks I had read through that one as well as the V1 part of that thread as well. Good info for sure....seems like XR has moved on to other things. If I was only doing this years ago...what a huge amount of knowledge he had.
Could use some of his advice on a very small sealed sq sub to look at for this build among other things!
He has been pretty quiet lately, but he is still around.
I have the aluminum version of those mids paired with the same tweeters in my trailblazer and I am very impressed with it! I also have the same mids paired with a set of css tweeters in my Cruze hatch and they sound great too. I prefer the sb tweeters though. For the sub, I have the 12" dayton reference HO in a ported 1.3ft3 tuned to 32hz. It's not an spl monster, but it sounds very clean and musical. I have also run it sealed at .88ft3 and it also sounded great, but it just wasn't enough output for me. In my other setup, I run a ported 15" idmax so I'm use to having more than enough substage. Also, I am running the dsp 408 and am super happy with it. Don't think you could do better than it with anything twice the price.
Wanted to give an update and some pictures of my progress to this point. Looking for good sources and prices on my listed parts and still looking for what sub and amps I want.
In the mean time I did install my Kicker Hideaway sub under the front drivers seat for that much needed boost to the stock system to get me by until I can get everything else rolling.
Unhooked the negative battery cable....believe it was a 10mm socket.
Vehicle Car Fender Automotive exterior Auto part
Red Auto part Vehicle Car Vehicle door
Then took out the drivers seat bolts so I could better access the space under the seat. Used a T50 Torx socket and a little bit of muscle but no breaker bar needed.
Bumper Vehicle door Automotive exterior Trunk Technology
Automotive exterior
Automotive exterior Bumper Auto part Tire Automotive tire
Vehicle Vehicle door Car Auto part Automotive exterior
I thought about completely removing the seat for complete access but I hit a roadblock in this yellow connector that I didn't feel confident enough about pulling on without knowing how it worked to mess with it so left it. Any help on how to disconnect this would be welcome for future reference.
Auto part
I then started prying up the drivers side sill panel to run cables....find a ground...and hoped to see all the wires in the kick panel not knowing if it would be on the drivers side like it is in the Cruze or on the passengers side which would be the drivers side on the Cruze. Some pics of the connectors holding the sill panel in. No wires but a very nice ground to use!
Bumper Automotive exterior Trunk Auto part Vehicle
Vehicle Automotive exterior Bumper Car Trunk
Vehicle Automotive exterior Car Auto part Hood
Automotive exterior Bumper Auto part Vehicle Car
I ran the bass control knob up the drivers kick panel and into the little flip down storage cubby where I'll use a 3M pad to mount it in there which keeps it completely hidden.
Vehicle door Automotive exterior Technology Trunk Auto part
Vehicle Car Auto part Audio equipment Trunk
Underneath the seat when test fitting the sub I realized there was a fancy cable tie thing stuck down just far enough to keep the sub from sliding in another inch or so which is certainly needed as the space is very limited under there. Cut that out and will just use a cable tie after install to keep the wires out of the way instead of this chunky thing hanging down in the way.
Reptile Snake Vehicle door Bumper Scaled reptile
Black Asphalt Red Road surface Soil
Ran the ground wire under the carpeting and foam to that before mentioned nice ground spot.
Red Bumper Automotive lighting Technology Vehicle door
Red
Ran the power cable back to the battery....again under the carpet and foam down the drivers side sill to the back seat. Went to the side/under the backseat just by pulling the wire through to the area where the battery is and connected it there. Will tidy up the wiring and cable tie it where needed. 10mm socket needed again from memory.
Red Wire Technology Electronic device Cable
Red Wire Auto part Automotive lighting Technology
Continued........
Now needing to find somewhere to tap into the rear left and right channels for the high input on the sub I went over to the passengers side kick/sill panel and lo and behold I found the wires. Only issue is that its alot of wires and not much slack at all. Since I was wanting to preserve the rear speakers at this point and just tap into them I did not feel comfortable trying to fit 4 taps into that group of wiring so thought I'd look at the pillar near the rear speakers and see if it would be easier to do it there.
Wire Auto part Vehicle Electrical wiring Technology
Wasn't too hard to take the pillar panel off....just the same connectors with two half hinge like pieces at the top.....getting it back on a completely different story. Don't attempt it unless you completely remove the seat as the angle you have to put it back on at is only possible when the seat isn't there. You have to put the top connectors into the holes at an extreme angle and then the rest just clips back on.
Trunk Automotive exterior Bumper Vehicle Vehicle door
Light Bumper Automotive exterior Automotive lighting Auto part
This exposes a hole covered over by tape where the speaker wires are. Again I was disappointed that its just too tight with no slack to get some taps in there comfortably.
Automotive exterior Hood Bumper Auto part Vehicle
As much as I was trying to avoid pulling the head unit I felt better about doing that and tapping into the wires behind it where I knew there would be enough room to work and install the taps comfortably. I took the drivers side center console panel off so I could run the high level wires behind the head unit.....just a few connectors. The wires run mostly under the carpet and foam to enter the center console area.
Tire Vehicle Auto part Automotive tire Automotive exterior
Vehicle Car Trunk
Wire Electrical wiring Technology Cable Electronic device
Trunk Vehicle Wire Car Floor
How for the head unit....not alot of fun but at least there are some videos showing this. I'll post more photos of that process later but the two tricky parts is getting the main trim piece off without breaking it as its rather flimsy and the connectors are fairly hard to pop...hoping the next time they pop a bit easier and I'll have better tools. The other hard part is getting the two air vents out. There are two little tabs that need to be pressed down at the same time to slide it out...one is very visible and easy to see but the other is a bit hidden and may need a pick tool of some kind to actually hit it properly. A picture of the wired behind the head unit once you get behind it.
Technology Vehicle Car Electronics Auto part
I tapped into the green(LR+) & green/black(LR-) as well as the white(RR+) & blue/black(RR-).
Tuned it up and everything works great!
1 - 7 of 7 Posts
