1 - 10 of 10 Posts
Quite different from the US model Diesel.
What's the pedigree of that engine?
I believe it is a German design made in Austria. Even though it first appeared in Australia in the Australian built Cruze it is a newer design than the US engine. It has duel chain driven OH Cams and replaced the single belt driven OHC of the 2009-2011 Korean made Cruze. It is now also the only engine available in the Indian Chevy Cruze.
Some figures on it I was able to find.
Engine manufacturer:
GM
Engine type:
diesel
Fuel type:
diesel fuel
Fuel system:
common rail
Charge system:
turbocharger
Valves per cylinder:
4
Valves timing:
VVT (variable valve timing)
Additional features:
Delphi EMS, intercooler
DOHC
Emission control:
DPF, oxi-cat
Emission standard:
Cylinders alignment:
Line 4
Displacement:
1998 cm3 / 122.4 cui
Bore:
86 mm / 3.39 in
Stroke:
86 mm / 3.39 in
Compression ratio:
16.5 : 1
Horsepower net:
120 kW / 163 PS / 161 hp (ECE)
/ 3800
Torque net:
360 Nm / 265 ft-lb
/ 1750 - 2750
Horsepower gross:
Torque gross:
Redline rpm:
Car power to weight ratio net:
76.9 watt/kg / 34.9 watt/lb
Car weight to power ratio net:
13 kg/kW / 9.6 kg/PS / 21.4 lbs/hp
Fuel capacity:
60 liter / 15.9 U.S. gal / 13.2 imp. gal
Engine lubricant oil capacity:
7.1 liter / 7.5 U.S. qt / 6.2 imp. qt
Engine coolant capacity:
7.5 liter / 7.9 U.S. qt / 6.6 imp. qt
Acceleration:
0-20 mph (s):
1.8
0-30 mph (s):
3.1
0-40 mph (s):
4.4
0-50 mph (s):
6.4
0-60 mph (s):
8.5
0-70 mph (s):
11.2
0-80 mph (s):
14.8
0-90 mph (s):
19
0-100 mph (s):
25
0-110 mph (s):
33.5
0-120 mph (s):
49.6
0-130 mph (s):
101.4
Whoa! A few things jump out:
7.5 quarts of oil. I like that
VVT is something we don't yet have. I'm also intrigued to see the stroke/bore ratio is now square. Wonder why the change there.
Is that an aluminum block?
Thanks for digging that up.
Cast iron block, alloy head. Also redline is 4,500rpm.
Interesting that they shortened the stroke and reduced the redline. Usually, it works the other way.
Designed from scratch by a different team. Longer stroke better torque short stroke lower piston speed, both have different advantages.
Does the Australian Cruze Diesel have an overboost feature? On the North American Cruze, I believe it increases maximum torque from 264 ft/lbs to 280 ft/lbs for up to 10 seconds at a time.
Discussion Starter · #10 ·
No, it really doesn't need it as you never feel like you don't have enough power. I had 4 adults and holiday luggage in mine and overtook an 18 wheeler that was travelling at 90kph in a 100 zone on a country road. I found myself doing 140kph so easily it surprised me. The car is just nice to drive, I am hooked on diesel from now on.
Reactions: pacolino
1 - 10 of 10 Posts
