1 - 3 of 3 Posts
my 2012 chevy cruze has a P0700 P0716 P07BF does anyone know where the speed sensor A circuit is located?
A would be the sensor on the right
Definition of check engine code P07BF:
Generic (Common for all car manufacturers) - Input shaft speed (ISS) sensor/turbine shaft speed (TSS) sensor A - circuit low
More often then not, the cause of this code, P0700, is that there is a transmission problem of some kind.
The TCM detected the problem and set a code. P0700 means that a fault code is stored in the TCM. However this doesn't rule out the possibility of a failed PCM or TCM (unlikely).
Read more at: https://www.obd-codes.com/p0700
Potential causes for this code, P0716, to set are:
Damaged, loose, or burned wiring and/or connectors
A faulty input speed sensor
A defective output speed sensor
Malfunctioning transmission torque converter
PCM failure or a PCM programming error
Read more at: https://www.obd-codes.com/p0716
Code: P07BF - Input Speed Sensor. Story Inside
1 - 3 of 3 Posts
