Just bought a 2012 cruze LT 1.4 turbo. I’m having an issue upon start up the automatic light control goes off/on constantly for a minute or 2 then stays on and works fine. But if I open the door it will happen again if I pop the truck it will happen again. And I also have a clicking going on at the same time on the passenger side. Which I can think is bcm. When the automatic light control stays on that clicking noise also stops and it’s a separate noise than the hazard light noise. To complicate things more the headlights will flicker coinsighting with the clicking noise and the constant on/off. And if I pop the trunk that blinking will happen with tail lights and with license plate lights. I am getting B3883 bcm code with no check engine light. A short to battery that’s constant and an open circuit b3883 that’s goes in and out.
