I'll be second in line.If they make a software update for it, I'll be first in line
Sent from the sexy electrician
Just makes it that much easier backing up if you can have an idea of where the edges of your car are. Most cameras also have the lines that move with the steering wheel so you can gauge how far to turn your wheel. Nice feature and makes it a lot easier backing into a spot with larger cars.Just out of curiosity, why are the guidance lines important to you guys?
Because the camera is such a wide angle, guide-lines would be helpful to see where the car's actually pointed.Just out of curiosity, why are the guidance lines important to you guys? I don't care either way as I very rarely use my camera, typically just to make sure I don't back into the garage wall when parking it.
The Sonic has the Grid but the lines don't move?Just makes it that much easier backing up if you can have an idea of where the edges of your car are. Most cameras also have the lines that move with the steering wheel so you can gauge how far to turn your wheel. Nice feature and makes it a lot easier backing into a spot with larger cars.
Actually, since there are no grid lines, I do use my right side mirror to back into my apartment stall at home. But I do use the camera to make sure there's nothing in my way. I'm not conformable with the view that I get with just mirrors or turning my head. Not after the level of visibility I had with my first two cars. Not that the Cruze is bad, it's just all new-ish cars seem like that to me. Backing up is a act of faith without the camera.Or just use your mirrors![]()
Hopefully the 2016 Cruze will as well.15's have it, before is just a camera.
But then the lines will be there for all modes - like the entertainment system.I believe someone can make a clear sticker with lines in it... well it will not move with your steering wheel but should give you an idea.
