Big Zeus Build Thread
28964 Views 252 Replies 16 Participants Last post by  Dave's World
10
Ok, after a long period of contemplation, I have decided to go ahead and make a thread documenting my 2013 Cruze LT 1.4L. I will name it a build thread, but don't really consider it that. This is just something that I work on and improve as time and funds allow. I like to tinker and find different ways to do things as well as maximize performance. I do all the work in my enclosed garage and have a decent amount of tools. Most if not all of the modifications will be bolt on.
Maintenance/work list:
Window tint 12/1/2018 54k
New tires 55000 discount tire
Paint correction and wax 55k
Dorman thermostat 4/25/2019 55k
Transmission fluid drain and fill valvoline 55k 5/10/19
Front rotor resurface 55k 5/10/19
BNR tune purchased and installed
New plug boots rock auto standard brand 55k 5/17/19
New battery (larger size) and negative cable OEM and mechanical boost gauge 55k 5/23/19
Transmission fluid drain and fill AC Delco
56k 6/28/19
Oil change and filter 56,048 7/12/19 super tech synthetic
ZZP downpipe 7/15/19
Installed black vinyl over emblems
New ac delco ceramic brake shoes front 56,300 8/23/19
New driver window motor and tint 9/4/19
New belt tensioner and belt ac Delco 11/24/19 | 56,500
digital boost gauge 12/14/19 56,600
Fixed turbo outlet line coolant leak and installed new water pump. New antifreeze 56,700 1/9/20
Changed oil penzoil ultra platinum 5w30
57,322 3/22/20
Compression right to left
180,200,195,205 Psi
5/5/20 57,541 new oil gm, oil pan reseal, ac Delco turbo oil line 89in lb, 22 ft lb, down pipe reinstalled
Brembo brake rotors 6/15/20
Bnr wastegate actuator 6/20/20
AC Delco spark plugs default gap 8/17/20
Ac Delco water outlet new prestone dexcool antifreeze 8/28/20 57,922
Dorman intake manifold 9/20/20
New purge valve OEM, BNR throttle body spacer, boost leak test passed 9/30/20 58008
New MAF Ac Delco 10/21/20 58106
New FCS front struts 58,500 1/18/21
New FCS rear shocks 58,600 2/23/21
Oil change pennzoil plat ultra, BNR LS7 coils 58669 4/12/21
New GM water pump and gasket
58,700 4/28/21
BNR Intake manifold spacer, new driver CV Axle, Cardone reman.
59,000 11/6/21
Rotated tires
59,111 11/20/21
ZZP V3 Turbo, used 1500 miles
59,300 04/02/22
Oil change Pennzoil Platinum
59,360 04/03/22
ZZP Ported intake manifold, PCV 3.4 fix kit
59,450 04/22/22
And the story begins:
When she was pretty new, she was full of swirl marks and scratches. This is after a professional paint correction that I did myself with the pictured Meguiars and harbor freight DA. Tons of work and it took days. I went panel by panel.
292234
292235
Next, got some new shoes (Continental Control Contact) These things are great, so much softer than the old Michelins
292236
Shortly after, it was time to start fixing leaks. This was the first one, I fabbed up a piece of rubber tubing and put a heat shield on it. It has lasted almost 2 years now with no leaks.
292237
292238
Had a transmission fluid leak that was likely from an overfill, did a drain and fill X3 with AC Delco fluid.
292239
292240
Next was a rich condition, which I finally narrowed down to the cooler NGK plugs I installed, Don't go with the 8's... unless you like unburnt fuel
292241
Next up is oil leak time, the oil cooler and pan were leaking. The dealer fixed the pan and for some reason painted it all with silver spray paint... I did the oil cooler a month or two on my own after. More to come in next post
292242
292243
continued below...
241 - 253 of 253 Posts
Nice, BNR actually sells them now, I am just not looking to spend $400 for four injectors ATM.
Power costs money. What more can I say. :LOL:
Battery is at 10V this morning, barely turns on the lights; ordered a walmart H6 AGM as a replacement with delivery (poor delivery person lol). Current battery lasted just over 3 years, right out of warranty of course.
Wow, that's even worse than the 1st gen CTD batteries.
:LOL:
Only 3 years?
I've never had a battery last less than 5. And it gets cold here OCT. Through MAR. :LOL:
:LOL:
Only 3 years?
Probably part of the issue, not enough use with lockdowns and working from home.
I used to tell people who didn't drive much to take a drive on the highway that surrounds the city every 2nd Sunday. That's roughly 35 miles. I figured that was enough to recharge the battery and boil the moisture out of the oil.
Got my injectors in today. 52 lb. Boschs. now just awaiting tune update. What do y'all use on the o-rings, motor oil, vasoline?
I use a synthetic grease called Super Lube.
Spent this evening wiring up the flex fuel kit from @Dave's World /Super Cruzes and flashed the updated tune. The kit I got is the integrated one, it uses the MAF plug I assume for power and only has one pin that goes into the ECM. Around an hour install with 30 minutes cleaning the wires up. I am still on 93, it ran good, but fell on its face at WOT and under high boost. Either spark blowout or valve float, but it occurred at only 4500RPM, so not completely sure. Will gap plugs down from stock tomorrow and test further.
Hey how are you? I didn’t see a notification till today. What injectors are you running? What is your plug gap and your boost PSI?
You're all good it's not a you issue ;) I was running the GM cadillac ones BNR tunes for, but have since switched to Bosch 52's. Just waiting on a tune update now. Gapped plugs down to .025, boost is a little hot reaching all the way up to 25PSI or so, I did ask for them to turn that down a bit in the tune.
That’s an exciting build. If you ever need help just message me!!!!!
  • Thank You
Tune seems good with the 52lb injectors. My ZZP wastegate actuator is overboosting even at no preload, so I guess I need something else. The stock one will barely hold 18PSI lol I didn't like the Forge wastegate actuator because I felt like it stuck on and off and the boost went up and down, but may have to go back to that. I may give the mambatek a try. or if I can find springs replacements swap them in the ZZP one. I know the zzp is just rebranded china wastegate anyway...
Message me via email and I can elaborate more about the wastegate. And help you get fixed up on your boost issues.
