Update, cleaned up bottom of engine and no seepage so far!
Yes, as it says in my post the dealership gave it this paint job last time they resealed it, or didn’t reseal it. 🧐 and yes a GM dealership.Paint removal? My oil pan is unpainted aluminum...
Nah, got it all over the axles, frame rails, tranny as you can see... No clue as to why they thought it was a good idea.Oops. I must not be able to read today.
That's malicious. Did you report them to GM?
either Or. You can choose!Does that thing go ober the existing heat shield?
That turbo almost has to touch the hood, yeah? Side note, do you know where that GSP intake adapter came from that you shipped with the v3?I can't choose. I don't think it'll fit in my engine bay. But other people can.![]()
Interesting. So no need to double lock then?When you press lock once it locks and a few seconds later turns on the alarm.
I actually just lock it with the door switch most of the time. I know that the earlier Cruzes have a different door lock location on the dash.
Ok it didn’t fit. I may try to mess with it some more at a later time. This fit though! Although it was very tight.In the never ending quest to search for less plastic parts I have uncovered this. I am going to compare it to the original tonight and give it a test fit.
Say whaaaa?! Where’d you get it?I have one of the aluminum oil filter caps.. mine fit just fine ..
Yeah, even worked on them a bit with a dremel, no dice.Fairly certain it was an Ebay purchase though mine didnt have the "GM" packaging .. have you measured OD of both caps at the threas and compared the threads ? checked to make sure there wasnt just a knick or something holding it back ??
Care to share the link where you got yours? I had to go back to plastic… Never got one that would thread in sadlyI have one of those. Fits like a glove.
I did it myself, used a metal pry tool that is used for mobile phones to split the halves apart.Where did you have that done? I have a key fob, but cant get the old one open to switch the guts.
Sure, this is it! Best Metal Spudger Tool for Pry Separation Screen Removal Open Cell Phone Repair | eBayCan you post a picture of or a link for it?
