im kidding....im not the big zeus
pulsing under medium throttle which I thought was tune related or wastegate actuator, but I guess not... it was exhaust leaking and pushing through the crack.Wow...
That's kinda disturbing.
Were you noticing any issues?
Put some oil in the bearings and store indoors In the BIGGEST Ziploc bag you can find. Or something equivalent. They key is to keep the outside out and keep the turbo clean and dry.Got the replacement manifold in. Here it is along with the stock turbo. Look at that crack! Got a good working spare now. What’s the best way to store a turbo?
I'm happy to see used performance parts get new lives.Spent the evening tearing the Dorman intake manifold off and installing the used ZZP ported one from @JLL. The nipple in the Dorman intake one has a black blob on the center, very interesting and it also seems warped. I have a feeling it may have failed or was failing. I installed a 3.4+ fix kit on the ported intake and took it out for a spin. Definitely more pull on the top end and less on the low end. Blue spring is overboosting a bit I think, but no boost cut or codes.
Have a good break!Alright. Well I’ll be taking a break from this site for awhile. My thread was deleted that I had made attempting to inform people of two of the aftermarket companies business practices and how they alter product reviews. ✌🏻
That's pretty big!Got the replacement manifold in. Here it is along with the stock turbo. Look at that crack! Got a good working spare now. What’s the best way to store a turbo?
Yeah even went up to the top it looks like. That manifold was shot.That's pretty big!
How big is your intake tube?My next task is fitting this into the intake 3.0 OD x .5 Airflow Straightener Screen .187 honeycomb cell mass air flow | eBay. I want to give it some smoother air to see how it affects things; the stock intake of course has an air straightener. It definitely can't hurt.
3"How big is your intake tube?
Which brand intake are you using?
