121 - 140 of 183 Posts
· The Nuclear Option
Did you clear the codes and try again? Limp mode causes all sorts of weird stuff and codes. Ask me how I know lol.
Yes it does. This one time, at band camp....
Oh, Sorry wrong story.
Last summer when I replaced my intake manifold, I lost the clip that secures boost bypass valve solinoid electrical connector and thought, "Oh, it'll be ok." Then a month later after the E85 install, I went to do a WOT run for a data log. It pulled hard at full boost. When I let off and went to take off again for a stop light, nothing. No boost whatsoever. And then an check engine light. I thought I blew something up! :LOL:
When I got home, I pulled a P0033 (Turbocharger or Supercharger Bypass Valve Control Circuit). The boost bypass valve control solenoid electrical connector came off. I plugged it back in a searched the driveway for the clip I lost a month earlier and somehow I found it.
· COTM Winner
Its the little things that matter :LOL:
· Administrator
Discussion Starter · #123 ·
I have not yet, but the codes did not appear until the next morning as I was looking at my Scan Gauge on the way home when it happened.
What has me a bit worried is the odd tick. It could be a piece of some part that broke free causing the codes to show up.
2013 Cruze LT
Aside from wiring issues or a bad sensor... It sounds like you may have a larger mechanical issue unfortunately. Especially with a ticking sound. Think the chain tensioner is loose and you’re hearing that through the valve cover? I bet so. Was it loose enough for the chain to skip a tooth, also plausible.
Skipping a tooth on a chain would be very hard. You would have to have sheared a tooth on a gear. Sorry to hear Blasirl keep up us to date. A compression test may yield if the timing is jacked. You could be ticking because the ecu knows the equipment sensing the timing is off.
Is the 1.4 an interference engine? Hope you get this resolved bud.
· Administrator
Discussion Starter · #130 ·
The ticking is irregular, like a piece of metal is bouncing around. It is not very loud either.
· Administrator
Discussion Starter · #131 ·
Thanks, will do.
· Administrator
Discussion Starter · #135 ·
If this is the case, I would drive it as little as possible until you figure out the issue.
Do you have a second vehicle you can drive?
Unfortunately no, our household is already down one vehicle and I travel about 200 miles plus every eight days.
What about the cam solenoid/phasers? How does the ECU know what position they are at? Maybe if there is a feed back circuit for those you may have one going bad? But the ticking could be part of the tensioner assembly or just a chain with a bad roller somewhere. Is there any sort of rhythm to the ticking?
· Administrator
Discussion Starter · #138 ·
No rhythm, kinda random.
· Administrator
Discussion Starter · #140 ·
I was just going back over these conversations in case I missed something. I just saw you mentioned the E85 install here. Did you install the Racer-X version?
