This is uncommon for the 1.8.
Given the P0171 code (as well as the P2270) and blue smoke, I believe you still have an issue with the PCV integrated into the valve cover (yes, this is for 1.8's too, but far less common of an issue).
I would take it back to the shop where the valve cover was replaced and have them test it. Typical PCV checks include pulling out the dipstick or oil cap at idle - smoke should NOT puff out the opening; this indicates positive crankcase pressure that the PCV system SHOULD be re-routing into the intake manifold.
The P0324...I'm not sure. It may be throwing knock codes because it's running lean.
