Has anyone else added a boost gauge specifically tapping into a BNR throttle body spacer? Most of what I have read has the boost gauge tapped into a line just behind and underneath the intake manifold. I have added a new electric AEM boost gauge today and tapped into my BNR spacer. The most boost I saw when on the pedal was 3 PSI. I have not checked for any boost leaks as of yet but wanted to reach out to the community to see if anyone got this specific combination of parts to work.
NOTE: I was hoping to comment on an existing thread but couldn't find any that were super recent with recent activity.
2013 Cruze LT
I do. Not a bnr spacer, different company but shouldn’t matter. I see all the way from -23 vacuum to 25psi boost on it.
285513
Awesome. Thanks for the quick reply on this. I will go hunting for boost leaks then in my system I suppose. Did you end up adding a fuse using a fuse tap or did you jump into an existing fuse for your setup?
2013 Cruze LT
I already had a fuse tap on the ignition for my dashcam, it turns on and off with they key, ran another line into it and works perfectly!
Odd enough I added a fuse tap today but couldn't any fuses that were not 'constant' hot on the interior fuse panel, as in the ignition did not have to be on to get power.
2013 Cruze LT
I can go snap a pic of my fuse panel at some point if you'd like.
2013 Cruze LT
I verified I have it on fuse 2, the power outlet. That turns on and off with ignition.
Super weird. I went back out and moved the fuse tap to the empty fuse 2 and it does the same thing in my car. Stays on all the time. The car doesn't have any electrical issues that I know of so not sure at this point if that is by design or if I am just going crazy.
2013 Cruze LT
My bad it’s fuse number 6 and 7(one is rear the other is front power outlet). No idea why I typed 2. It won’t go off until you open the driver door also. But to me that’s no biggie.
Reactions: gh0stwr1ter
Discussion Starter · #11 ·
That makes sense now. I was literally just looking at the diagram again thinking I had misread which were the power outlets. Haha. I tapped into fuse 7 and it works perfectly now. Thanks for all your help again and quick responses.
I installed a mechanical boost guage to a DDMworks TBS with no issues. It also has a port I used for the PCV fix as well.
I cannot find the post where I installed it, but here is where I installed the gauges:
How-To: Install gauges in a ZZP Pillar Pod A-Z Part 1
285424
285425
This is an enlarged pic
285426
