No.
Recirc valve > BOV.
Recirc valve > BOV.
If you're hearing the intake roar through the BOV, then you are having some issues...heheEvery time you hear the intake roar it can remind you of the sucking sound your wallet made when the purchass took place.
Won't help the car a bit.....kinda cool to look at....beyond that.....ehe.
Correct, installing one of the Forge BOVs will not give you any extra power. Just for sound and looks, in less you go larger turbo that does not have the BOV built into the turbo like our stock turbos. Then modification is required for external BOV and MAF relocation.So basically the consensus is, if I wanna hear the woooosh, get one, if not, spend the money somewhere else! Gotcha! Thanks guys! LOL!
Suck/blow......you know what I meant......give the old guy a break.If you're hearing the intake roar through the BOV, then you are having some issues...hehe
Sorry Mark... We have a BOV built into our stock turbo?in less you go larger turbo that does not have the BOV built into the turbo like our stock turbos.
Yeah I think you're right. At least not an atmospheric bovI'm quite sure the 1.4L's turbo does not have a blow off valve from the factory.
Right - just a standard BPV. Vents to intake.Yeah I think you're right. At least not an atmospheric bov
On my Supra, the only reason I upgraded the BOV was because of the significantly higher boost pressure. Needed a stronger BOV to handle the boost when the throttle slams shut. I have the HKS one and you can tune the sound with different inserts. Being that the Supra is a big inline 6cyl you have to be really on it to make the BOV chirp. Couldn't see adding a BOV to my Cruze unless I was running a much higher boost pressure.The point has been made already, but I'll share my experience (which you can also find by searching around). You can't use a BOV without a tune and there are 3 important things that you should know
1. The car runs like crap. at least mine did even after a bunch of tweaks from trifecta. But, the car did run stronger at WOT.
2. It's so sensitive that it goes off at the slightest let off of the throttle so everyone either looks at you like you're an a$$ or they think you're trying to race
3. The noise sounds like a bus's air brakes and does not sound cool. No chirp, just a puff of air.
However, if you want a worthy mod, replace the stock BPV with a better BPV (no tune required). This will be especially helpful if you plan to get tuned.
If you're still running the stock twins, it doesn't take much at all to make the BOV release. Heck, I was running a single (PT-57) and mine would "flutter" at the lowest of RPMS/throttles. Didn't take much at all to get to 0+ PSI.On my Supra, the only reason I upgraded the BOV was because of the significantly higher boost pressure. Needed a stronger BOV to handle the boost when the throttle slams shut. I have the HKS one and you can tune the sound with different inserts. Being that the Supra is a big inline 6cyl you have to be really on it to make the BOV chirp. Couldn't see adding a BOV to my Cruze unless I was running a much higher boost pressure.
GooIf you're still running the stock twins, it doesn't take much at all to make the BOV release. Heck, I was running a single (PT-57) and mine would "flutter" at the lowest of RPMS/throttles. Didn't take much at all to get to 0+ PSI.
